20 Most Recent Daewoo Sensy LCD20KAT 20 in. LCD Television Questions & Answers
2answers
Where or how do I
It is commonly located at the back of your tv and it is printed there, You should have a hdmi cable and if you connect it already, press in the remote for the video setting and you will see there the AV1, AV2,HDMI1,HDMI2 try to choose the slot where you plug the HDMI cable or try to look for the manual for sure. Good day and best regards.
7/31/2011 12:34:35 PM • Daewoo Sensy... • Answered on Jul 31, 2011
2answers
I don't have the remot of my DAEWO LCD20 KAT-T
You wont find that anywhere - that format is proprietary and noone else is using it. All you can do is to take advantage of the learning capabilities of the logitech harmony 700 remote: buy a cheap universal remote make sure its buttons are fully functional , then enter the commands one by one from the universal to the remote : put the remotes face to face then press the same button on both . The exact procedure is in the manual of Logitech. Once all the commands/codes are in you can upload them directly from your remote.
10/15/2010 3:35:52 PM • Daewoo Sensy... • Answered on Oct 15, 2010
3answers
Need the IR HEX codes
below is the best I can get for you.
http://mine.remotecentral.com/cgi-bin/codes/daewoo/inctec/
I would suggest you contact the manufacturer of your
DAEWO LCD via phone or e-mail and request for the IR HEX codes from them. They might give it to you or direct you to a dealer where you can get the user IR HEX codes.
This is the best you can do to get the
IR HEX codes you are requesting for.
Good luck.
10/15/2010 3:18:55 PM • Daewoo Sensy... • Answered on Oct 15, 2010
0answers
2answers
I accidently pulled a yellow power plug out from somewhere inside the tv, now i can't find out where it goes or connects to, could somebody help me here?
If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
9/29/2021 11:46:44 PM • Daewoo Televison... • Answered on Sep 29, 2021
Will a Daewoo DRVT-40 play S VHS tapes
sorry no clue here
7/10/2021 8:29:20 AM • Daewoo Televison... • Answered on Jul 10, 2021
3answers
Necesito el codigo de un control universal
English: the universal remote codes for Daewoo TV are: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Try those - I hope they help a bit.
Spanish: los c?digos alejados universales para Daewoo TV son: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Intente ?sos - esperanza de I que ayudan a un pedacito.
I had to translate (roughly) from the asker's question. Here is where I got the list from:
http://dogbytecomputer.com/universal-remote-control-code-list.html
9/20/2020 11:59:21 PM • Daewoo Televison... • Answered on Sep 20, 2020
I have an old daewoo tv that will not connect to a universal remote
https://codesforuniversalremotes.com/remote-control-codes-for-daewoo-tvs/ Set up the remote control app
  1. On your phone, download the Android TV Remote Control app from the Play Store.
  2. Connect your phone and Android TV to the same Wi-Fi network.
  3. On your phone, open the Android TV Remote Control app .
  4. Tap the name of your Android TV. ...
  5. A PIN will appear on your TV screen.
https://support.google.com/androidtv/answer/6122465?co=GENIE.Platform%3DAndroid&hl=en
4/29/2020 6:47:14 PM • Daewoo Televison... • Answered on Apr 29, 2020
2answers
Would I be able to
I don't know if this will work, but try opening your dvd player with no dvd inside and with your controls press 0000 this hopefully will bring up a screen where your region settings are. Set it to 0 and press okay. This may make your dvd region free and should be able to play any dvds form any region
if not try here
http://www.dvdexploder.com/multihacks
1/20/2020 6:59:43 AM • Daewoo Televison... • Answered on Jan 20, 2020
2answers
Remote control rc-801BA for Daewoo Smart TV led 32 works inconsistently for Youtube works fine, Netflix impossible to stop, forward o reverse, HBO all the forward or backwards bottoms works forward!!
Basically you need to buy a new remote as the buttons do wear out or get dirty over time, and repairing them is pretty much impossible.
9/14/2019 11:32:49 PM • Daewoo Televison... • Answered on Sep 14, 2019
NECESITO LOS CODIGOS PARA TV DAEWOO DE UN CONTROL UNIVERSAL RCA414BHZ
no hay in el folio? Es possible que no hay para este especifica Tele... pero pueden investigar en otro conrol universal de RCA....possiblemente 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058. Utiliza cada una, hasta ver si una funciona... Bueno suerte
2/22/2019 4:58:01 PM • Daewoo Televison... • Answered on Feb 22, 2019
I got a new classic remote for a daewoo tv cant get it to do anything
Are the batteries good? Do you see any lights (if it has any) when you press any of the buttons? It this a universal remote? Have you programmed the remote for your TV?
2/2/2019 6:21:34 PM • Daewoo Televison... • Answered on Feb 02, 2019
Hello . Please help me with My Daewoo crt tv is stuck on standby mode .. Thanks. Model no. DTQ 14V5L
not enough information... when the tv is on standby then there should be a led on...what happens when on is pushed...is the light then flashing or remains the same...starting point is to check the powersupply rails... a circuit would be helpfull. This tv is an old CRT type which would have a b+ rail of aprox 150v and how that rail is set up is important (feedback and protection may shut down the rail)
11/21/2018 11:27:50 AM • Daewoo Televison... • Answered on Nov 21, 2018
0answers
Daewoo Sensy LCD20KAT 20 in. LCD Television Logo
10 questions posted
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Televison & Video
Most Popular Question
or
  • Televison & Video
