20 Most Recent Westinghouse LCM-19v1 Monitor Questions & Answers
It has possibly decided to close down. Some monitors have a power shutdown as power saver of two or more levels. It may wake up from pushing a button on the monitor. Check on the screen settings to see if monitor can stopped doing this. I had a monitor that did this years ago, long since replaced.
Westinghouse... | Answered on Sep 08, 2017
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Westinghouse... | Answered on Feb 25, 2015
Most likely the capacitors on the power board have failed. I had the same problem and replaced (2) 1000 mfd/25 volt and (3) 220 mfd/25volt capacitors. Problem fixed! I used Radio Shack #272-1032 and #272-1029 capacitors.
Westinghouse... | Answered on Aug 30, 2013
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Westinghouse... | Answered on Oct 08, 2012
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Westinghouse... | Answered on Jul 14, 2012
Hi there.
I have written a very helpful tip about this problem recently.
Check it out here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Westinghouse... | Answered on Jan 18, 2012
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If your problem is not the capacitors then it would be the backlights and that is much more difficult to replace.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Westinghouse... | Answered on Dec 17, 2011
Let find out first if it is the powered speakers in the monitor problem or in the PC sound card problem.
Feed the monitor with sound source such as MP3 player to see if you do get the sound, if not, more likely to be bad speaker amps circuits problem which will not be worth putting the money to have it repair since you can spend the repair money on a good set of power speakers that will you so much better sound than the monitor built-in speakers about the size of a quarter.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Westinghouse... | Answered on Jan 09, 2011
Starting looking for bad caps in the power supply.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Westinghouse... | Answered on Oct 07, 2010
More likely to be bad caps in the power supply, you will have to invest money in tools to do the repair.
Please read on so you will have some ideas if you want to fix it or not.
Westinghouse... | Answered on Aug 31, 2010
In that case the problem is now with the inverters or the connections to the CCFL tubes. You need to test it again, and this time focus on the inverters and their connections.
Westinghouse... | Answered on Aug 07, 2010
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Westinghouse... | Answered on Apr 29, 2010
Yes, it is, it is just the picture board that is faulty. since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Westinghouse... | Answered on Apr 26, 2010
Did you turn up the both (at the PC Audio control panel and at the Monitor control panel) volumes up?
Try using MP3 player or any audio sound sources feeding the monitor audio input to see what happen also.
Westinghouse... | Answered on Apr 10, 2010
If the screen is all white glow and no pictures, it means the LCD panel is not getting the 5vdc for the LCD controller board, it can be as simple as the LCD panel connector came loose or you do have the 5vdc supply. You need to open it up and inspect the inside for burnt parts, loose connectors, bad caps, etc. see some pictures here: http://s807.photobucket.com/home/budm/allalbums
Westinghouse... | Answered on Mar 14, 2010
hi this could be due to the fact that the resolution is set incorectly on the other computer, try lowering it to the minimum at first then increase the resolution and see what happens...hope this helped
You may have failing power supply due to bad caps, look inside for caps with bulging top first, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Westinghouse... | Answered on Feb 14, 2010
Westinghouse LCM-19v1 Monitor Logo
61 questions posted
Top Westinghouse Computers & Internet Experts
ByRuss
Level 1 Expert
efs_perpends
efs_perpends
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Computers & Internet
Most Popular Question
westinghouse lcm 19v7 monitor stays few
  • Computers & Internet
