20 Most Recent Canon i9100 InkJet Photo Printer Questions & Answers
I suggest you unplug the machine from power, remove all paper from the feed slots, lay out some news paper. Then turn the printer upside down, hold it over the news paper, and give it a couple of healthy whacks on the base. See what falls out. If lots of junk falls out, put it all back together and try a test print. If the paper still doesn't feed, you may need to clean the pick-up roller with a cloth damped with water, a drop of detergent and a few drops of alcohol.
Canon i9100... | Answered on Nov 08, 2017
I doubt the waste tank is full, as the wide carriage printer can hold much more. As for cleaning, be very careful. I ruined 2 printheads for my using "magic" cleaner. Must have soaked the flexible traces together or apart. All I get is the bad head signal now..
Canon i9100... | Answered on Aug 16, 2013
When you attempt to print from your Canon Printer using a Mac, a message appears stating Error 306. Solution
  1. Click the Apple icon in the top left of the screen.
  2. Click System Preferences.
  3. Click Print & Fax.
  4. If the padlock in the bottom left is locked:
    Click it, enter your password and click OK.
  5. Click the - button. to remove the printer and the + to add it again leaving the options on default..
Canon i9100... | Answered on May 19, 2012
Hi
You can try this I found.
Reset Procedures for Canon i9100 Printers
  1. Turn off Canon i9100
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i9100 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Canon i9100... | Answered on Apr 14, 2011
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Canon i9100... | Answered on Feb 17, 2011
Hi. Are you referring to your printer that is not turning on?
Canon i9100... | Answered on Sep 13, 2010
http://www.google.com/products?q=Canon+QY6-0039&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=fAR4TMu0IcT7lwfp2dDrCw&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDIQrQQwAA
That is a link to the printhead for your printer which runs about 80$. After Installing your Printhead
You may need to perform a head cleaning routine after installation and the print head will need to be re-aligned, refer to your user manual on how to do this. Also if you haven't already try a printhead cleaning:
Perform print head cleaning to improve the print quality. Ensure that the printer is turned on and follow
the instructions below.
• Windows
Open the printer driver settings screen and click the Maintenance tab. Click Cleaning.
See page 14 for details on how to open the setting screen.
• Macintosh
Open the Page Setup dialog box and click Utilities. Click Cleaning. Here is a link to the guide as well.
http://gdlp01.c-wss.com/gds/2/0900005582/01/i9100quickstartguide_en.pdf
Thank you,
Lee
Canon i9100... | Answered on Aug 27, 2010
check your ink status maybe you need to replace you ink cartridges you may have run out of ink, you will encounter these when you need to replace your ink or theres a paper jam in you printer
Canon i9100... | Answered on Jun 13, 2010
  1. In Control Panel, click Printers.
  2. Right-click the bidirectional printer, and then click Properties.
  3. Click the Ports tab, click Enable bidirectional support, and then click OK.
    Also if parallel port, this is also set in BIOS, under LPT port settings.
Canon i9100... | Answered on May 17, 2010
If you havent used it in a while then you will need to replace your cartridges.
Canon i9100... | Answered on May 11, 2010
I've had the Canon i9100 since 2003 and have excellent photo printing results. In 2009 it started playing up and I'd gt some banding. More recently, black didn't want to print. It was as though the black ink in the print head got dry some days.
April 2010 - The colours started printing strange and I bought a brand new print head and installed it. Only takes a minute. Still had an issue with photo printing. Black and white was excellent but colours weren't true.
Found advice online to try cleaning the print head to print head carrier electrical contacts by rubbing them with a rubber eraser.
I did that and now I'm getting perfect colour photo prints again.
I had been thinking about buying a new A3+ printer but this is old printer is now working as good as new.
Canon i9100... | Answered on May 09, 2010
Hi there your printer cartraidge becoming an empty. So please replaced it & your problem will be solve. Thanks
Canon i9100... | Answered on Mar 11, 2010
Canon i9100 InkJet Photo Printer Logo
Popular Tags
55 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon i9100 will not boot fix
  • Office Equipment & Supplies
