20 Most Recent Canon i9950 InkJet Printer Questions & Answers
Missing colour on print head alignment
Sounds like a clogged nozzle. Run a "Nozzle Check", and see. If you are missing some of the results, then run a cleaning cycle.
2/19/2018 2:36:03 AM • Canon i9950... • Answered on Feb 19, 2018
0answers
3answers
Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
3/16/2013 3:24:48 PM • Canon i9950... • Answered on Mar 16, 2013
Hi, I have a Canon i9950 that is marking all it's
Hello you can try this may do it
11/11/2011 10:08:06 AM • Canon i9950... • Answered on Nov 11, 2011
I need a CD/DVD tray
Unfortunately replacement parts aren't readily available for this printer, as it's now 5+ years old. Even if it was new, companies like Canon rarely produce parts for products in this price range. To them they're disposable, and it's cheaper and easier in the long run to provide a new machine for warranty support than to stock parts.
That being said, you may have some luck searching sites like EBay for a used i9950 that you can use for parts. Otherwise you may be stuck purchasing a new machine with CD Printing Capability.
Sorry for the bad news. Good luck in your search!
5/5/2011 3:26:57 PM • Canon i9950... • Answered on May 05, 2011
Operator Error. 5 flashing amber lights followed
Try unplugging the power cord, letting it sit off for 30 seconds, then plugging it back in.
4/22/2011 8:17:50 AM • Canon i9950... • Answered on Apr 22, 2011
La impresion de las fotos me salen con un tono
I have a similar problem but with green tone instead. I have tried everything and still does not work. This is a very expensive printer and do want to fix it. Did you get to fix yours?
Fleur
1/19/2011 11:57:33 AM • Canon i9950... • Answered on Jan 19, 2011
Photo Printer canon i9950. Cannot
may be your printers ink is low so change your cartridge
1/19/2011 9:13:48 AM • Canon i9950... • Answered on Jan 19, 2011
I can't print with cannon
Canon i9950 Printer -windows 7 Driver Problems
But the October 25, 2009 driver for 64-bit Windows 7 is at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=9870
Did you look for this at Canon?
9/30/2010 11:33:36 AM • Canon i9950... • Answered on Sep 30, 2010
Printer does not switch on
I dont want to make out you are thick or anything, but going back to basics, have you held the on/off button in for a second or 2, and you are pressing the power buttin, not the resume button? I say that because i made an idiot of myself by pressing the wrong button when it said press the resume button to continue, and after a few attempts I must have looked like a donkey. The pirnter "should" power on automatically when you send something to the printer, so if it's not doing that either, check your USB connection, and make sure you have the drivers up to date, I know these probably sound like no brainers, but you never know, also, you could check the switch pack, it could be faulty, check the wires behind it, 2 plugs.
8/9/2010 2:25:58 PM • Canon i9950... • Answered on Aug 09, 2010
Suddenly no ink coming from five wells (BK, R, G,
I have the same problem but it's only with the black ink, I removed the print head unit and run it under the hot tap till th ewater ran clear, then i soaked it in hot water and again run fresh water through it till it ran clear then left it in a bath of alcohol, i just used whiskey, but wouldn't recommend drinking it after, or before for that matter, I felt there was nothing to lose if it was a faulty print head as they are about £95 new. I had already run several deep cleaning programs and replaced the inks, but literally no black ink at all was printing. I havn'e tried it yet as it's still soaking, but I have also stripped the cover off the priinter and am trying to clean otu the waste ink tanks and absorbant pads, it's far to expensive a printer to just chuck out so here's hoping
Brian.
8/9/2010 2:12:39 PM • Canon i9950... • Answered on Aug 09, 2010
2answers
Ink pads need replaced
Don't know if you managed to get the cover off, but I just did, first you have to remove the 2 silver end plates, they are held on by 2 clips each, use a thin bladed screw driver and push it down into the holes marked with an arrow, one on the rear under the rear lid, that you stack the paper against, one on the front inside the front drop down cover that the paper comes out on. then release the four arrowed clips along the back and side of the printer and another 2 on the front, one on the cd lever side, and 2 on th eswitch side, one of these is hidden behind the switch panel which you have to remove and unplug, then the whole cover should just lift off
8/9/2010 2:06:47 PM • Canon i9950... • Answered on Aug 09, 2010
Operator error
8/5/2010 6:33:52 AM • Canon i9950... • Answered on Aug 05, 2010
I am getting a message
There is nothing as a maintenance tank in a cannon printer. We generally receive this error message as the printer requires a reset.
Please perform the below mentioned troubleshooting steps to have your issue resolved:
1. Turn off printer
8. Your printer should respond as normal.
Please let me know if the above steps have helped you resolve the issue.
Please rate the level of assistance provided.
1/19/2010 5:00:31 PM • Canon i9950... • Answered on Jan 19, 2010
Canon i9950 will not print with windows 7
try the following driver from canon site, it should work with windows 7:
http://software.canon-europe.com/software/0035868_0010043.asp?model=
download the file and open it. after installing the file, you should restart the copmuter and see if it works for you
1/11/2010 10:39:55 AM • Canon i9950... • Answered on Jan 11, 2010
Canon i9950 InkJet Printer Logo
Popular Tags
40 questions posted
old marine
old marine
Marvin
Marvin
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon i9950 operator error 5 amber
  • Office Equipment & Supplies
