20 Most Recent OKI C5800dn Laser Printer Questions & Answers
The toner sensor (43131601) is located on the right side of the sub-chassis that holds the Drum/ Image units. It may be defective.
Whit
Item, Inc.
OKI C5800dn... | Answered on Aug 17, 2010
Your indication regarding the 100% does not necessarily indicate a damaged chip (sensor).
Many chips do not work by actually sensing the toner but by usage or other tricks.
We cannot be sure about what happened but replacing the drum and affected items
should solve the problem. Needed parts may be found at
http://www.inkfilling.com/toner-refill-OkiData--C5800Ldn.html
OKI C5800dn... | Answered on Feb 23, 2009
You need to do s head clean.
This could take 2 or 3 goes but should fix it you will find head clean in the maintenance settings.
It eats the ink so only do as you need.
let me know how it goes.
Regards Craig
OKI C Office... | Answered on Feb 03, 2018
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
OKI C Office... | Answered on Jun 21, 2016
replace
1 fuser unit or
2 transfer belt
OKI C Office... | Answered on Nov 16, 2015
the best soloution is to replace the unit with a brand new one as reset fuses are difficult to work with on fuser units but if you search the internet you might be able to find a reset kit from alibaba or amazon
OKI C Office... | Answered on Oct 27, 2015
OKI C5800dn Laser Printer Logo
17 questions posted
Popular Products
Top OKI Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C OKI
  • C OKI
Most Popular Question
oki c5800 printer sensor malfunction
  • Office Equipment & Supplies
