20 Most Recent Acer AL2216W LCD Monitor Questions & Answers
I have an Acer Al2216W that has been working fine
Are there indicator lights on your monitor.
1/29/2018 9:42:57 AM • Acer AL2216W LCD... • Answered on Jan 29, 2018
My Acer AL2216W monitor this
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable" If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
4/4/2017 12:16:06 PM • Acer AL2216W LCD... • Answered on Apr 04, 2017
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
4/27/2015 12:04:32 PM • Acer AL2216W LCD... • Answered on Apr 27, 2015
3answers
My Acer AL2216W Black LCD Monitor all of a sudden
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
3/26/2015 5:51:49 PM • Acer AL2216W LCD... • Answered on Mar 26, 2015
2answers
Shadows around the objects
One common cause of ghosting is an inferior monitor cable. Remove any extension cables and check again. The monitor may be getting interference from another device nearby, such as a printer, for example. Try turning off/ disconnecting other devices and see if the ghosting disappears. If so, you could buy a better shielded cable, or rearrange your components to prevent the interference.
That would be a simple fix if it works....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
10/9/2014 5:12:48 PM • Acer AL2216W LCD... • Answered on Oct 09, 2014
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
6/4/2014 12:07:04 PM • Acer AL2216W LCD... • Answered on Jun 04, 2014
Power
There are monitors which have their own power outlet and there are some which don't have any. If you are sure that the monitor doesn't have power outlet, then make sure that you press on the power button. Please send me the model name of your monitor so that I can take a look at it and tell you what to do next.David
7/21/2013 1:48:34 AM • Acer AL2216W LCD... • Answered on Jul 21, 2013
Is this a power switch Problem?
YOU DESCRIBE THE PROBLEM VERY WELL.IF IT'S OLDTHE ADVISE WOULD BE START LOOKING FOR A REPLACMENT-MONITOR
6/13/2013 9:14:13 PM • Acer AL2216W LCD... • Answered on Jun 13, 2013
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
6/12/2013 10:31:29 PM • Acer AL2216W LCD... • Answered on Jun 12, 2013
3answers
I have same problem
Replace the following capacitors:
3 pcs - 220 microF - 25v
2 pcs - 1000 microF - 25v
1 pc - 2200 microF - 25v
Resolder the 2 transformer legs for the inverter.
Roan
Triangle Tech Whiz.
4/19/2013 3:38:29 PM • Acer AL2216W LCD... • Answered on Apr 19, 2013
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/ Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.Here is the inside of your monitor:http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
1/21/2012 5:24:21 AM • Acer AL2216W LCD... • Answered on Jan 21, 2012
2answers
Power on and monitor goes to sleep mode
You need to try it on another PC, alos verify if the VGA cable is good. If nothing change, then you need to open it up, first thing to look for are the capacitors in the power supply. Look for cpas with bulging top/seal, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
1/1/2012 3:28:48 PM • Acer AL2216W LCD... • Answered on Jan 01, 2012
2answers
I can see it faintly
It may have bad caps in the power supply, bad lamp assemblies, etc. You need to do visual inspections and voltage checking.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL2216W/
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
1/1/2012 3:24:01 PM • Acer AL2216W LCD... • Answered on Jan 01, 2012
3answers
Acer AL2216W back light stoped working 2months out
3/4 light up means it is not getting the full drive voltgae or poor solder jopints at the end of the lamps, try swappin the top and bottom lamp assemblies to see if the problem follows.
You need a set of test lamps for testing the inverter circuits.
http://www.badcaps.net
Lamps: www.lcdparts.net
11/15/2011 1:49:58 AM • Acer AL2216W LCD... • Answered on Nov 15, 2011
Acer AL2216W LCD Monitor Logo
100 questions posted
Steve Sweetleaf
Steve Sweetleaf
shadow
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
see faintly
  • Computers & Internet
