20 Most Recent
Cavalry Storage CAUE37250 250 GB USB 2.0 Hard Drive Questions & Answers
I have data on my CAVALRY ext storage hard
sounds like it's time for a disk recovery exercise. Check the repair directory on fixya for your zip code. That's about all you can do at this point. Hope you had it backed up.
Constant beeping from Cavalry external HD
Can't say exactly what it means technically speaking, but my experience with such a problem is that the drive is 'dead'. Of course trying it on another computer would be constructive.
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives.
When the bleu light does not go on, you have to assume the drive is not getting power.
If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone.
If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive.
If both don't work, it also could be inside the housing of the drive is something defect.
If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net.
Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
Error message says I don't
It sounds like your network administrator has locked your ability to write to certain folders. If this is a home hard drive, the only way to fix this would be to completely reinstall windows. If it's a work computer, you need to talk to your IT Department.
-Alex
CAUO37500 Lite's on but nobody
im not sure how bad your hard drive is but if it works on another computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps also
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
Transfer between 2 External Drives
the best program for this file transfer is Director Opus 9 this can transfer 100gig in under 1hr as with windows transfer takes 6hrs.
As I do alot of video capture and my filse range from 400mb to 4gig in size and having to transfer 700 gig about would take forever and with this program quick and easy you also can transfer over lan or wirless net.
happy transfering
Where I can get a perfect astrologer in India?
Hello friends, according to my recommendation, the best astrologer's name is Sai Balaji Anugraha. I met him for the first time in Bangalore and consulted with him over the phone after the pandemic.
He is the best Vedic astrologer in Bangalore who strongly believes in "Karma." He says that our present life is directly affected by our actions in the past, and by making positive efforts in our present actions, we can avoid future problems in our lives. Sai Balaji Anugraha always gives his clients hope and helps them figure out how to deal with their problems.
He helped many beings progress through their karma. He offers simple remedies that are effective and can be easily done by anyone.
How do i reset my account
With absolutely no clue where this account is, it is impossible to say. We are FIXYA, not your account people, we can help, but we need some clues.
Click COMMENT under my post.
