20 Most Recent
Hoshizaki Commercial Freezer SafeTemp® FH2-AAC Questions & Answers
Our freezer defrosted and nearly
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
8/12/2011 2:38:25 AM •
Hoshizaki...
Answered
on Aug 12, 2011
I have a hoshizaki freezer model FH1-AAC-HD, it stay on def
this is a large misconception of this unit. After a defrost cycle is completed, the display stays in "DEF" or "REC" until the box temp reaches 14 degrees of the "set" temp. So, if you have it set on zero, the conditioned space has to get to 14 degrees and then the display will switch over and show the temp. One way to verify this, is if the display shows DEF, check to see if the compressor is running, if so, then this scenario applies.
1/26/2018 3:51:33 AM •
Hoshizaki...
Answered
on Jan 26, 2018
Hoshizaki Model KM500MAH
When first turned on, the sump should fill with water. If it does, water solenoid is good. If you have a full sump, and no water pump running, sometimes the "Ice/Off/Wash" switch is bad. Put switch in wash, if pump runs, it's good. Now put in Ice position, if sump fills and pump does not come on and compressor indicates it is in the freeze cycle, replace that switch first. Simplest place to start and lest costly to fix.
10/5/2017 1:45:52 AM •
Hoshizaki...
Answered
on Oct 05, 2017
Unit will not power up
with no model number, I can only answer this way: most all Hoshizaki machines use at bin thermostat to send power to the control board. If the thermostat is bad, nothing works. As long as you have the right power and no blown fuses, look at the bin thermostat.
6/26/2017 10:10:40 PM •
Hoshizaki...
Answered
on Jun 26, 2017
