20 Most Recent
Hussmann Freezer DCSG-12-D Questions & Answers
Problem with hussmann chest freezer
If the freezer is not located in an area where grease vapors are present the unit can be cleaned off using a vacuum cleaner. Then use a flash light to look through the coils. If you see dust embedded deep inside use a small air compressor to blow out the dust. Dirty condenser coils raise the pressures and temperatures in the system. Cleaning the coils and scheduling them to be clean at quarterly intervals should keep it functioning for a long time. Operating with a restricted condenser takes its tole on the compressor life span.
10/29/2009 5:45:57 PM •
Hussmann...
Answered
on Oct 29, 2009
I have a hussmann g6f-8u and can't stop the ice
Most all freezers are set at a defrost of every 6 hours (4 times a day) and for about 25 to 30 minutes. This is a good starting point.
Be sure that the system is working right. If you are icing up, you may have other issues.
Hope this helps.
9/12/2009 2:08:20 AM •
Hussmann...
Answered
on Sep 12, 2009
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words.
That is an overheating fault. Replace the fluff with no fluff.
Make sure the condenser coils are free of dust and there is good airflow
Or
It is low on refrigerant gas and you need a service tech..
2/3/2024 5:25:13 AM •
Freezers
Answered
on Feb 03, 2024
