20 Most Recent Whirlpool LSR9434PT Top Load Washer Questions & Answers
KitchenAIde KAWS677EQ0 washer will fill,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
3/6/2011 2:53:57 AM • Whirlpool... • Answered on Mar 06, 2011
How Do I Remove Steel Case?
To open the cabinet is pretty easy. Follow this link for video directions.
http://www.youtube.com/watch?v=0XVpv8bFwGU
Hope this helps.
11/20/2010 11:27:01 PM • Whirlpool... • Answered on Nov 20, 2010
0answers
I cannot remove my waterpump
To keep from damaging the motor bearings you may have to take a hack saw to that pump. Seen it. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/23/2010 3:32:03 PM • Whirlpool... • Answered on Oct 23, 2010
Whirlpool washer LA5800XM has water
The water pump is often what leaks. You will have to remvoe the case of the washer to see if that is the problem. This page will help http://www.appliance-repair-it.com/Whirlpool-washer-leaking.html
9/3/2010 5:20:29 PM • Whirlpool... • Answered on Sep 03, 2010
My 7.5 kg top load Whirlpool Washer will rinse and
Best off to call a reputable service company such as Sears.
2/6/2010 5:50:31 AM • Whirlpool... • Answered on Feb 06, 2010
How do you remove the top on a whirlpool washer
Check out the video at the following link and see if it contains information that will be of assistance. Sure hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
9/24/2009 3:14:44 PM • Whirlpool... • Answered on Sep 24, 2009
2answers
It will not fill with water
how do you open top on whirlpool washer?
3/13/2009 6:16:17 PM • Whirlpool... • Answered on Mar 13, 2009
Agitator won't move
beetween the moter and trany there is a coupling
5/15/2008 1:25:33 AM • Whirlpool... • Answered on May 15, 2008
2answers
Whirlpool wtw5850sw0
look over the top of the control panel look straight down you see 2 phillips head screws on either side youll need to remove, the console will flip back giving you access to the switch..just for curiosity its not "clicking" when you close the lid therefore it fills and stops, doesnt spin or drain???? try this first.open the lid all the way, the left side hinge acts as the plunger for the switch.. feel under there open and close lid a little to help find the metal hinge. after finding the hinge place a 1/4 nutdriver(doesnt matter the size just needs a hollow shaft.) over the protruding portion of the hinge. still under the top but right there! when its on push the driver back(in essence bending hte armature back slightly). itll flex a bit as you push the hinge the door will push back(you got the right spot then). after you crank it back a bit try closing the lid now. did you hear it click??? your golden!!!!!!! no need to change.. reason for telling you this is for the most part the switch doesnt go bad but the lid /hinge isnt bent enough to make contact, and over time of swinging top into the fully opened position it actually bends to far forward to make contact. i have a box full of switched that other techs ordered and weren't needed. not saying they dont go bad ive seen that, but try this first might get lucky!!!!
4/7/2008 10:08:29 PM • Whirlpool... • Answered on Apr 07, 2008
Whirlpool top load washer 7.5 kg
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
9/27/2007 3:30:41 AM • Whirlpool... • Answered on Sep 27, 2007
Whirlpool washer
there are two springs which support the tub. you'll need to remove the top of the washer to get at these springs. at each front corner there is a bent spring clip which must be depressed. once you depress this clip the top moves upward. use a thin putty knife to depress the clip. in the back are two more clips held in place by a screw. after you spring up the top front corners the whole top can be removed and rotated towards the back.
9/3/2007 7:31:48 PM • Whirlpool... • Answered on Sep 03, 2007
Washing machine spins slow
If your machine is spinning slow, this can be an indication that your gearcase (transmission) may be going bad. One way to tell is to look under your machine. If you see any oil puddles on the floor, your gearcase needs replaced. A new gearcase runs about $200 and that doesn't include the labor charges (add about another $150). Good luck.
3/24/2007 5:32:29 AM • Whirlpool... • Answered on Mar 24, 2007
2answers
WILL NOT SPIN
Lady Victoria, you are going to have to remove the cabinet to get to the lid switch. Remove the two screws from the back of the top consol and flip it up. Unplug the lid switch and remove the snap springs. The cabinet will now lift off and you can get at the lid switch. I will attach some helpful pics...Catriver..post back
3/22/2007 9:51:33 AM • Whirlpool... • Answered on Mar 22, 2007
Washing Machine won't empty water during the cycle
does the timer advance by itself? if not the problem is your timer not advancing through the cycles. if timer does advance then being 14 1/2 years old it could be the motor. start the washer and mark the beggining where the timer starts. whatch it to see if it moves if not then you need to replace your timer
2/4/2007 4:13:26 AM • Whirlpool... • Answered on Feb 04, 2007
Whirlpool cabrio will not spin
If your Whirlpool Washer is not spinning the problem is almost always the lid switch. If the lid switch is bad you will not hear the motor running when in spin. To check the lid, first unplug the washer.
11/25/2021 12:49:50 PM • Whirlpool... • Answered 3 days ago
Estate by Whirlpool won't drain Video to YouTube now will post the link in a moment.
please check this brandboostr
11/18/2021 5:59:38 AM • Whirlpool... • Answered on Nov 18, 2021
Whirlpool LSR9434PT Top Load Washer Logo
23 questions posted
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
remove top whirlpool washer
  • Washing Machines
