20 Most Recent Continental Manufacturing Company Commercial Freezer Value Line 1FX-LT-GD-HD Stainless Steel Questions & Answers
Need more info. there are 2 lines. which one or ones are you interested in knowing.
Continental... | Answered on May 29, 2019
still looking for an answer to this question? will be glad to help. just let me know.
As a general rule of thumb, pressure on low side should equal a temperature of about 17-18 degrees if the box is not hot and a high side of ambient plus 30. Again, this is a general rule of thumb that usually gets you close enough to get a unit working providing all other things are right.
Continental... | Answered on Aug 08, 2017
sounds like you covered most all bases. without knowing pressures, I would look for a possible restriction. Since the TXV was replaced, are you sure you went back with OEM? If refrigerant was weighed in, was the drier an oversized one? It's rare but I have found some units that just don't cool right with the factory weigh in charge. You may want to try to charge by pressures. If it has a condensate pan with a hot gas line, be sure it is dry before trying as this effects the pressures. Good luck. Looking forward to hear about the fix.
usually depends on the temp of the conditioned space. Most freezers run about a minus 10 evap to get a 0 degree box. So look for a low side pressure of about 25. High side is ambient plus 30. A 75 degree ambient, for example, add 30 and get 105 degrees. That, on a P/T chart converts to about 253 psi. Those are approximate but I'm sure you can use this to fugure out what to look for.
let me know if you need more help.
Continental... | Answered on Oct 06, 2010
There are video's on google that have trouble shooting for Igloo ice maker types and for the Igloo ice company and YouTube.
Freezers | Answered on Aug 05, 2020
Cool and keep cool.
Freezers | Answered on Aug 04, 2020
Question posted under freezers but appears to be Ameriwood Industries furniture.
If you can identify the model number, you can download a free manual from Ameriwood Industries, which has a contact phone number to call for another model if that is different model furniture.
Example with telephone number:
https://www.ameriwoodhome.com/eng/AmeriwoodFiles/ProductDocuments/AmeriwoodFiles/ProductDocuments/19452_B345531309KP00%20instruction%20manual.pdf
https://www.ameriwoodhome.com/eng/instructions
Freezers | Answered on Jul 01, 2020
I wonder what the fixya software asterisked out?. Can you write the word
v
e
r
i
c
a
l
l
y
Freezers | Answered on Jun 29, 2020
Hi I have the same problem,
did you get an answer to your question..?
Freezers | Answered on Jun 15, 2020
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
That alarm light means that the unit was too warm for a period of time. The door may not have closed properly. It is a warning to you that the food may have thawed out. It does not mean something is wrong. To reset it switch it off and on or unplug it for a minute.
Freezers | Answered on Jun 14, 2020
https://www.bestbuy.com/site/shop/freezer-with-lock
Freezers | Answered on Mar 27, 2020
https://industrial.panasonic.com/ww/products/motors-compressors/compressors/reciprocating-compressors-fs/d-series-reciprocating-fixed-speed-r134a-lbp/D110C21RAX5%2528RSIR%2529
Freezers | Answered on Mar 21, 2020
Continental Manufacturing Company Commercial Freezer Value Line 1FX-LT-GD-HD Stainless Steel Logo
9 questions posted
Top Continental Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Continental Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Continental Freezers
Most Popular Question
pressure 404a freezer
  • Freezers
