20 Most Recent
CyberPower 1350VA UPS w AVR & LCD (CP1350AVRLCD) UPS System Questions & Answers
Backup unable to communicate with computer
Plz check your computer without ups.If it is runing there.And wattage of ups .It seem over load or shortage of ups.Check power cable.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
300 watt manual
Your not asking the right question. The answer is dependent upon how long you want the backup to work. Does a battery fit in the unit or is it alone? If you were to connect a car battery to the unit it would run for many hours, say a motorcycle battery would run maybe an hour. It is all about the time you want for run time.
