20 Most Recent Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Samsung... | Answered on Jul 14, 2016
If a new set it is somewhere on the back. Check your manual for exact location.
Samsung... | Answered on Feb 15, 2016
If I had a dime for every one of these type of questions I could retire without my pension. The problem with these sets today is that they no longer fall under the category of "durable goods" which include washers, dryers, water heaters, furnaces, etc. They now come under the electronics category. This means that you shouldn't really expect these devices to last much longer than their warranty period. The days of TV sets lasting 10-15 years are over. Three to five is the new norm. They are designed with obsolescence in mind. The manufacturers do not build any tolerances into the electronics so any small power surge or glitch can cause a cascading failure through the device, taking out multiple board with it. You replace one, it works a few minutes, and then it gets blown out by another one that was bad as well. By the time you get through replacing all the boards, if you are lucky enough to get it working again, you find that for a buck or two more you could have bought a new one that was larger and with more features. This is the manufacturer's plan. If TVs lasted 10 years, then they can't keep selling them at the rate they can build them now. If you want one of these to live a little longer than normal, invest the hundred bucks or so into an UPS to attach to it for power and surge suppression. Dollar store surge protectors won't do much to save these touchy devices.
Samsung... | Answered on Nov 22, 2015
This sounds like an internal electronic failure. If you are lucky it may still have some warranty. Check with the place you purchased it, they may be able to warrant it or repair it. This is not a DIY project unless you have the equipment necessary to do the repair.
Samsung... | Answered on Dec 06, 2014
It sounds like an internal electronic failure. If you are lucky it may still have some warranty. Check with the place you purchased it, they may be able to warrant it or repair it. This is not a DIY project unless you have the equipment necessary to do the repair.
Connect the power cords for the soundbar and the subwoofer to the back of each, and then plug both into a wall outlet. Use a small pointed object to press the ID SET button on the back of the subwoofer. Continue holding until STANDBY turns off and LINK (Blue LED) blinks quickly.
Samsung Audio... | Answered 2 days ago
Electronic store cud hav a generic part or ucud maybe rigg one up
Samsung Audio... | Answered on May 20, 2020
It would be simpler to buy a new remote for the 321 system. Spares for this system are not very expensive. A remote will probably cost less than £20.
Samsung Audio... | Answered on May 02, 2020
Sound drops out from the wireless subwoofer. The sound on your wireless subwoofer can drop out if there is interference or a physical obstruction between the soundbar and subwoofer. Make sure the subwoofer is within range of a good signal of your soundbar, and that the issue is not with the source audio.
https://www.samsung.com/us/support/troubleshooting/TSG01109876/
Samsung Audio... | Answered on Apr 15, 2020
SOLUTION: This was happening to us for over 6 months, lately its every few minutes, i just figured out its due to faulty front touch pad, if you open the unit and remove front face of the player, remove the single small ribbon wire that connects to front touch pad, leave the other little ribbon wire as this is for the remote control IR receiver, only the remote control can work with this now obviously.
Samsung Audio... | Answered on Apr 10, 2020
  • There may be DVD region limitations on your device, and you use a DVD disc that is not listed in your device.
  • It may also be the vendor of your brand DVD disc, including those that are not recommended.
  • The format of the files on your DVD disc, does not support.
  • Disc Optic is dirty / dusty. Clean it.
  • Disc is scratched.
  • Damage to the disc player.
This picture is captured fromf the User Manual, page 6.25840297-l1qpqmriditabltrjczr2eku-4-0.jpg
Samsung Audio... | Answered on Apr 07, 2020
I have a Samsung HT w/bluray, but I don't know what "cinavia" is. Sorry!
Samsung Audio... | Answered on Feb 14, 2020
Fixing a Cheapo Chinese MP3 Player
  1. Step 1: Opening Up. First unscrew the screw. There is only one! ...
  2. Step 2: Fix. I disconnected the battery first by unsoldering it. ...
  3. Step 3: Put It Back Together. Test it first and keep cleaning till it works! ...
  4. Step 4: The Battery. Someone commented that they wanted to see the battery.
www.instructables.com > Fixing-a-cheapo-chinese-MP3-Player
Fixing a Cheapo Chinese MP3 Player : 4 Steps - Instructables
Samsung Audio... | Answered on Feb 12, 2020
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Logo
9 questions posted
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
when turn tv will automatically turn off
  • Audio Players & Recorders
