20 Most Recent LG Electronics 55LE5400 55LE5400 55 LEDLCD TV Direct LED Questions & Answers
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
LG Electronics... | Answered on Jul 16, 2016
The move may have resulted in surround mode being deselected. The speaker sound check will not detect this.
LG Audio Players... | Answered on Nov 19, 2020
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVD from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware that allows you to play DVDs from any region. There are severalavailable on the Internet but my favourite is DVD-Region Free From:-
www.dvdidle.com/dvd-region-free.htm
LG Audio Players... | Answered on Jun 23, 2020
hahhaa, I recommend you to throw it out.
and check out problem here on triveditech
https://www.triveditech.com/
LG Audio Players... | Answered on Apr 13, 2020
There are several reasons that this could happen and given the cost of a new one VS the experience you need and the tools and test gear, it would be best to get another one.
Could be a sticky power of function key, bad laser, bad motor, bad power unit, bad detector
be sure bluetooth is on. also turn both headphones off. once headphones are off, start scanning for bluetooth devices. once scanning, hold the power button down on both earbuds for ten seconds or until theyre both flashing red and blue. your device should then notify you about pairing.
LG Audio Players... | Answered on Dec 27, 2019
Did you check all connections? All audio settings? If yes and it didn't help I think better will be call to specialist in this field. I recently bought new home cinema Ugee 1910B and it works perfect. Quality of video and sound is great.
LG Audio Players... | Answered on Dec 24, 2019
Have you changed the Regional Code of the DVD changer? Changing of Regional Code of the Changer is permitted for 5 times. To view movies of different region code, some people change it. Suppose you or someone have viewed a movie of different region movie after changing the region code & now you are trying to view a DVD of your region. In this case you will have to change the region code to your region. Changing of region code is available through the setup of the Changer.
-sonsunny
LG Audio Players... | Answered on Dec 06, 2019
Manuals here
https://www.lg.com/za/support/support-product/lg-ARX8
Depends what inputs and outputs your TV has, and whether you also have a cable box or other source.
LG Audio Players... | Answered on Nov 16, 2019
Whether the remote, or using any buttons on the unit, those inputs go into a microprocessor(computer within your unit). There can be other issues, but that is the most likely.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
LG Audio Players... | Answered on Oct 16, 2019
if any of the selector switches is dirty this will happen.
a drip of wd40 into every micro switch should solve it unless it is a dry solder joint on any of the switches.
did you try unplugging it, waiting 30 seconds, and plugging it back in?
LG Audio Players... | Answered on Aug 31, 2019
Hi Leslie, I send you the link to download the LG LH-CX247W service manual
I hope you can resolve your concern
Regards Franco Dosil
Hola Leslie, te env?o el link para que descargues el service manual del LG LH-CX247W
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://elektrotanya.com/lg_lh-cx245_cx246_cx247_cx640.djvu/download.html
LG Audio Players... | Answered on Aug 15, 2019
LG Electronics 55LE5400 55LE5400 55 LEDLCD TV Direct LED Logo
1 questions posted
Top LG Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • LG Audio Players & Recorders
Most Popular Question
led tv screen flickered momentarily
  • Audio Players & Recorders
