20 Most Recent Whirlpool GBD307PD Electric Double Oven Questions & Answers
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Whirlpool... | Answered on Jun 06, 2017
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
This is often due to a control board failure. The board may be NLA (no longer available). It can be rebuilt with a 2 yr warranty. See: http://www.fixyourboard.com/boards/4448876.html
Whirlpool... | Answered on Sep 01, 2015
E2 F6 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced.
Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Whirlpool... | Answered on Aug 19, 2015
What I know about this is that the board may be bad. Does the rest of the oven work ok? If you don't want to spend the money on it and it still works, you can clean it manually. Assuming it is not under warranty, you may just have to get a local tech to look at it. Normally, I can tell by the code what the problem is, but I honestly am not sure. Try one last thing and just turn off the oven at the breaker and back on after about 15 seconds and see if it resets itself. This sometimes has worked.
Whirlpool... | Answered on Dec 21, 2014
HI. This will be the result of a failed touch pad assembly. Use the procedure below to isolated the issue.
1. Once you have gained access to the touch pad assembly, Inspect the keypad connector for firm a connection. The Key pad will be connected to the rear of the man control board. Check the connectors for a firm connection. Move to step two if the connection is secure.
2. Press CANCEL. If the error code returns after 60 seconds, replace your keypad (also called touch pad or membrane switch). Some models may incorporate the keypad and control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Whirlpool... | Answered on Mar 20, 2013
I called a repair man to come out and fix it.
hi there. i have located the manual and posted the link below.
PARTS MANUAL
We have here a video showing how you can check the temperature sensor
We also here the parts diagram of your model
Whirlpool... | Answered on Aug 22, 2011
The problem is with your element. Most of these can be bought at local hardware stores or appliance part stores.
The easiest way to tell if it is the element is to check the element itself you will need a few tools to do this one of which is a multi meter with continuity.
Testing Element:
  1. Shut off power to the unit this can be accomplished by flipping the breaker or unplugging the unit from the wall.
  2. Remove the rear panel of the Range (on freestanding ranges), on wall ovens you may be able to remove the screws that hold the burner in place at the back and pull the element and wires forward (Be careful not to let the wires go back in side the wall as you will have to pull the oven out to reconnect the element)
  3. Remove the wires that are attached to the terminals on the element
  4. Use your continuity tester and place one lead on each terminal if no continuity the element must be replaced. (If tests good need to test oven switch)
  5. To replace the element do all of the above and remove the oven racks, unscrew the bracket that holds the element in place at the back inside of the oven, pull the element out and replace with the new one
Whirlpool... | Answered on Apr 25, 2011
If you have power to the oven, it must be the thermostat. They can fail open circuit. You can check it wth a multimeter.
If its out you can easily replace it providing you can get one.
Whirlpool... | Answered on Jan 25, 2011
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Whirlpool... | Answered on Dec 26, 2010
Whirlpool GBD307PD Electric Double Oven Logo
51 questions posted
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Ovens
  • Whirlpool Ovens
Most Popular Question
whirlpool double oven accubake
  • Ovens
