20 Most Recent
Gibson Intertherm Nordyne Miller Fan Motor 1/10 621587 6215870 Condenser 208-230 Questions & Answers
What are the BTUs for a Gibson Room Air Conditioner model # GAS256Q2A1
Contact your local technician and specialist of the company in which you bought this product. Check out their FAQ page and help page then contact them for further information. Follow this link to get started
https://www.manualslib.com/manual/889218/Gibson-Room-Air-Conditioner.html
Gibson furnace blinking 4 times then pauses, flame won't stay on
The four flashes is failure of ignition. It could be the flame sensor dirty. The furnace tries to light four times before you get the four flashes. The board then locks out for one hour unless the power is removed and restored. You could try gently cleaning the flame sensor with fine steel wool. If you don't have fine wool you can use a crisp dollar bill.
with the burner firing the yellow flame sense indicator should be pretty much locked on or flicker briefly. If it just occasionally flashes on then the flame sensor rod needs to be cleaned.
hope this helps you.
Frost on coils on condensers
i will assume you are talking about evaporator --a few reasons restricted air flow coils dirty -air filter clogging --fan not working or operating properly --low on freon ---turn fan on and with a spray bottle mix water and a little liquid soap and spray coils the fan will pull mixture thru coils keep spraying do not wipe the coils you can get injured and also damage coils an replace with new filter if still freezes over will need to check freon level and fan operation
