20 Most Recent Dometic 3313192.000 White Single Zone LCD Thermostat Heat/Cool/Fan Questions & Answers
5answers
My Dometic digital thermostat wont go up past 32 degrees. What could be wrong?
Same problem...then discovered my thermostat was set to Celsius instead of Ferinheight... pressed toe temp up and temp down buttons to change..fixed...
7/12/2020 1:44:23 PM • Dometic... • Answered on Jul 12, 2020
How to wire six wire to three wire termenal
I'm pretty sure this thermostat uses digital communications with a dometic control board. In other words, there are no contacts in the digital thermostat to turn something on and off. Even if you ran a 12VDC wire to the thermostat for power, it won't work to replace a "real" thermostat. I bought one to replace my old analog thermostat and it's not going to work for me.
12/2/2016 5:29:57 PM • Dometic... • Answered on Dec 02, 2016
No error message.. unit turns on,cycles and does not come back on
sounds like relay module,
8/20/2015 10:00:03 PM • Dometic... • Answered on Aug 20, 2015
Getting E1 error - Loss of communication between the single zone LCD thermostat and the module board. Manual doesnt give a solution or fix.
unplug cable at both ends. remove cover from t-stat. using contact cleaner spray contacts on cable and points it connects to. if necessary replace t-stat and cable
8/20/2015 10:05:56 AM • Dometic... • Answered on Aug 20, 2015
Not getting power - fridge is - 2nd air conditioner is??
check breaker and fuse it will be seperate from 1st a/c
8/19/2015 8:03:49 PM • Dometic... • Answered on Aug 19, 2015
AC fan runs when heater is turned on in RV Dometic single zone
the heat and cool use the same fan. if compressor is running with heat then you have relay issue
8/18/2015 7:33:37 PM • Dometic... • Answered on Aug 18, 2015
Heat wont turn on
thermostat, relay module,heat strip, fusible link.
8/18/2015 4:49:49 PM • Dometic... • Answered on Aug 18, 2015
Why is the air conditioner and furnace both on at the same time in my RV
relay module issue.
8/18/2015 4:43:08 PM • Dometic... • Answered on Aug 18, 2015
Air will not turn off when tempture is reached
bad thermostat or relay stuck in.
8/17/2015 9:59:40 PM • Dometic... • Answered on Aug 17, 2015
Why is my thermostat showing a e2 fault?
Indoor coil temp defective. Replace it.
7/16/2014 2:09:18 PM • Dometic... • Answered on Jul 16, 2014
What is a E4 code mean
Error Code:E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System will shut down.E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling operation will be locked out. Fan operation can continue to operate.E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be locked out. Fan operation can continue to operate.E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat Pump operation will be locked out. Air Conditioner, Fan and Furnace operation can continue to operate.E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-poi
1/28/2013 2:47:50 PM • Dometic... • Answered on Jan 28, 2013
2answers
Awning retracts at random
some awnings have a sensor that retracts the awning if wind elevates to certain level. i wish mine did. i have seen them ripped off rv's.
9/29/2021 7:16:14 AM • Dometic Heating... • Answered on Sep 29, 2021
Dometic 3313192.000 White Single Zone LCD Thermostat Heat/Cool/Fan Logo
17 questions posted
Top Dometic Heating & Cooling Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Heating & Cooling
Most Popular Question
dometic digital thermostat wont go up
  • Heating & Cooling
