20 Most Recent Frigidaire FRA186MT2 Window Air Conditioner Cooler - 18500 BTU/h Cooling Questions & Answers
If moisture/water gets to the control board it will/may cause it to act this way. Or the control board may have a short. It may also have a bug, mouse, or gecko laying on the controls. Something causing it to "misfire" or short. If a visual inspection does not show evidence then its probably control board failure.
Frigidaire... | Answered on May 27, 2015
Hello, you can use a drain hose and coonect it to the outlet of the drain hole. This way you can terminate the hose away from your neighbor.
Frigidaire... | Answered on Apr 10, 2014
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Frigidaire... | Answered on Jul 24, 2012
probalbe causes may include loose connection, voltage drop (undersized circuit conductors), wrong type of fuse, bad compressor, motor or capacitor,
Frigidaire... | Answered on Dec 23, 2020
Thank you for your post, John!
Based off the information you have provided you need the code for a universal air conditioner remote. You may need to speak with manufacturer of the remote for that direct code. Best of luck! -Matt
Frigidaire... | Answered on Jun 11, 2020
Make sure that the cooling coils are clean. Also that the cooling fans are working. It may have lost it's treon and it is time to buy a new one.
Frigidaire... | Answered on May 20, 2020
yes, but when it is running, does it also turn off??
Frigidaire... | Answered on Jul 26, 2019
Could have clipped the low voltage wire outside with a weed wacker, could have blown out the run capacitor or lost a major component! If the unit is buzzing when you turn it on but nothing's running (compressor or fan)then you have a failed run capacitor! The list of things it could be are endless without more info
Frigidaire... | Answered on Jul 13, 2019
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Frigidaire... | Answered on Apr 08, 2019
Are you sure you don't have a Heat Pump Condenser? You don't list the outdoor unit M#? If it is a Heat Pump system the outdoor unit has to run. Here is the link to the indoor unit. http://enora.nortekhvac.com/literature/a977a.pdf
Frigidaire... | Answered on Sep 11, 2018
with a meter you will need to verify motor is getting required voltage (high and low)Yes, its likely the motor but, do you put one in to see it still doesnt work?
Frigidaire... | Answered on Sep 07, 2018
if both are running you may be low on frreon, inspect for leaks before recharging.
Frigidaire... | Answered on Aug 10, 2018
Frigidaire FRA186MT2 Window Air Conditioner Cooler - 18500 BTU/h Cooling Logo
Popular Tags
3 questions posted
Top Frigidaire Heating & Cooling Experts
Jean Sintulaire
Steve Oakes
Steve Oakes
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
frigidaire window wall unit dripping
  • Heating & Cooling
