20 Most Recent Haier HRT02WNC Compact Refrigerator Questions & Answers
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Haier HRT02WNC... | Answered on Jun 13, 2011
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Haier HRT02WNC... | Answered on Dec 27, 2010
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Haier HRT02WNC... | Answered on Sep 11, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Haier HRT02WNC... | Answered on Sep 03, 2010
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Haier HRT02WNC... | Answered on Aug 27, 2010
More than likely, it needs a new control board. It takes about 5 minutes with Google to locate a new board. Runs about $30 (including shipping.
Warning, requires knowledge of soldering to install this board.
No, I had no way of testing the board. However, since the part is cheap and it came up almost immediately when I started searching, pretty safe to assume that's the problem. Yes, replacing the board solved the problem for me.
The control board is located behind the sheet metal on the back of the refrigerator.
I purchased my replacement board through www.repairclinic.com
Item # 1223802
Haier HRT02WNC... | Answered on Mar 09, 2010
you need a new rtc overoad contactor on your units compressor which is located in the rear of the unit,remove the spring wire that secures it to the compressor body and unplug and reverse procedure to install
Haier HRT02WNC... | Answered on Jan 17, 2010
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Haier HRT02WNC... | Answered on Oct 24, 2009
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Haier HRT02WNC... | Answered on Aug 05, 2009
some thing is wrong
Haier HRT02WNC... | Answered on Apr 07, 2009
1 year parts and labor
Haier HRT02WNC... | Answered on Aug 17, 2008
This is the replacement for the old one they stopped making the 260w
Haier HRT02WNC... | Answered on Jul 12, 2008
Freon "boils" when compressed and pushed through the evap. causing cold. Sometimes after time you can hear it making the boil sound. There is really no way to fix it. Well... There is a way to fix but the price you would pay to fix it; you could turn around and buy a brand new freezer! GOODLUCK:)
Haier HRT02WNC... | Answered on Dec 17, 2007
should within an hour if you tipped up on side and turned on before 24 hours ruined compressor
Haier... | Answered on Feb 01, 2020
Haier HRT02WNC Compact Refrigerator Logo
37 questions posted
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
refrigarator will not get items cold
  • Refrigerators
