20 Most Recent
Abernook Pasquini Livia 90 Semi Automatic Questions & Answers
Pasquini service in washington dc
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
7/4/2010 3:18:11 PM •
Abernook...
Answered
on Jul 04, 2010
Livia 90 Semi Automatic pump won't shut off during shot
Bansheracer is possibly correct. But, most likely the problem is the copper feed pipe to the boiler is plugged with calcium allowing the pump to continuously run without stopping. Most likely this is a problem you will need to have serviced. We are located in orange county, CA, and we can service, or Pasquini can service at 1501 West Olympic Blvd, Los Angeles 90015. If you are not in CA, let us know where you are located so we can send you to the closest authorized pasquini service center near you.
11/15/2009 6:44:17 PM •
Abernook...
Answered
on Nov 15, 2009
Livia 90 semi auto
I got hold of Pasquini directly and they most graciously talked me through it, admitting the instructions assumed more knowledge than average. In other words it was a polite way to tell me not to quit MY day job!
2/19/2008 11:07:07 AM •
Abernook...
Answered
on Feb 19, 2008
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
What does a CIMBALI M34 CODES ERROR 053 mean?
That .depends on software and configuration. It is not a universal code You might find help in the manual.
CIMBALI M34 SELECTRON USE AND INSTALLATION Pdf Download ' ManualsLib
Inspect Electrical Supply: Ensure that the machine is receiving proper electrical power. Sometimes, an interruption in the power supply can trigger error codes.
Clean Components: Check if any components related to coffee grounds or filters are dirty or clogged. Clean the underpan gasket, filter holes, and filter holder outlet hole.
Coffee Ground Quality: Verify that the coffee grounds are of the correct consistency. If they are too coarse or too old, it can affect the machine's operation.
Discharge System: Examine the discharge system for any blockages.
