20 Most Recent Whirlpool GR399LXHS Electric Kitchen Range Questions & Answers
Self cleaning F5 error
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$TRE
5/5/2017 2:50:29 PM • Whirlpool... • Answered on May 05, 2017
Stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
12/1/2015 1:06:53 AM • Whirlpool... • Answered on Dec 01, 2015
My Whirlpool Gold oven console will only respond
You will need to replace the control board. Here is the part to order.There is also a video on that page to show you how to make the repair.All parts come with a 365 day, any part, any reason return policy.
10/21/2013 11:51:39 PM • Whirlpool... • Answered on Oct 21, 2013
When self cleaning 30 min in get a e0 f5 reading and cleaning stops
E0 F5 = door latch failureHere is the part to order.
12/10/2012 2:17:54 PM • Whirlpool... • Answered on Dec 10, 2012
What are the dimensions
just measure the space using a tape measure. that will be your best bet.
11/27/2011 1:30:35 AM • Whirlpool... • Answered on Nov 27, 2011
Glass top range is pitted
Yes, your glass top assembly on your range can be replace. Here is one link where you can get the part, http://www.apdepot.com/Products/PartsLookup2/IPLLookupFrames.aspx?Brand=WHIRLPOOL&ModelNo=GR399LXHS1&ImgID=EdI2&ImgFile=WTKIKKLL
It is a relatively easy job to replace the main top since the burners are not attached to the top assembly itself. Remove 2 or 3 screws on the front of the top and you can easily lift the entire top off of the range and replace it with the new top.
4/17/2011 5:56:50 AM • Whirlpool... • Answered on Apr 17, 2011
Although the element knob is
Hello Shartrick,
The problem is the switch its self it is letting the power run thru it and not turning it off. You will have to take the back off of the range and locate which one goes to it.
1. Remove the cord!
2. Take the back off and locate the switch, Pay attention to the lines as they will have to go back to the same ones L1 to L1 of the new switch and L2 to L2 crossing these will burn up the other switches.
3. Remove the old switch pull wires first. Unscrew the two screws on the front that are holding the switch.
4. Screw the new switch in place and replace the wires
5. Replace the back of the range
6. Plug in and try the unit.
The switches can be purchased at www.easyapplianceparts.com
For the 8 inch burner switch #EAP336989 Cost $39.65
For the 6 inch burner switch #EAP336885 Cost $40.18
The full web page that you need is http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=gr399lxhs&searchTerm=img_D4IXLDKW&RefineSearch=0&imgMfg=Whirlpool
Thank you for choosing FixYa
3/7/2011 2:47:41 AM • Whirlpool... • Answered on Mar 07, 2011
What does f 02 mean
Hello there and thank you for choosing fixya:
The f 02 code is a very common code on these ovens
what this is telling you is that the ovens temperature sensor is faulty and is unable to read the correct oven temperature
So what you will need to do is to replace your oven temoerature sensor with a new one
tbirdfan1_37.jpg Temperature Sensor
Item # 722235
img-descriptiontab-on.png img-repairgurutiptab-off.png Oven temperature sensor
img-descriptiontab-off.png img-repairgurutiptab-on.png Watch our "Part Testing" video to determine if the oven sensor is defective or is not functioning properly and needs to be replaced.
Watch Video
Order now and this item will ship out today - or it's FREE!
$39.75 Quantity:
In Stock
2/17/2011 7:59:49 PM • Whirlpool... • Answered on Feb 17, 2011
Dual element on whirlpool gr563lxss range not
I have the same problem with the same model number. Any answers?
1/23/2011 8:28:19 PM • Whirlpool... • Answered on Jan 23, 2011
E1 F5 sign on panel control
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%^&*
10/1/2010 3:57:01 AM • Whirlpool... • Answered on Oct 01, 2010
Knob won't turn.
After disconnecting all power, it should not be difficult. (but then again, I repair restaurant equipment for a living) Make sure you mark the wires, and locations down in case you get distrracted, and make sure all your connections are firmly connected. A loose connection will cause the wire to burn down the line. If you are not COMPLETELY confident you can do it, call a professional.
3/31/2010 10:39:51 AM • Whirlpool... • Answered on Mar 31, 2010
Whirlpool GR399LXHS Electric Kitchen Range Logo
67 questions posted
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
e1 f5 sign panel r ncontrol
  • Kitchen Ranges
