There is a short in the wiring. Now you can repair this yourself or get a proffessional. I removed my back paneling an rewired mine by cutting each wire and twisting the same wire back to it.then I used some electrical tape to cover the open wires. Warning,you must have the dryer unplugged and you must connect the same wires together. If not you can cause an electrical fire.
Look and see if the button is stuck See the button to the right of my screw driver just above the model number tag? Sometimes they stick or plain go bad. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Most likely the problem with your dryer is a bad timer.Replacing the timer should solve the problem.Please get back to us if you have any further query.
there are knock out panels on both sides of the dryer. knock out the one you want to use with a hammer and flat head screw driver or chisel/ you will then have to remove the back and disconnect the vent going out of the back of the machine and reinstall a new hose or pipe on the outlet where you removed the vent and run it through your new hole to the outside vent.
The felt is two pieces. And, no, the problem is the drum support glides have worn through, allowing the drum to continue to wear into the front drum bearing. Replace the front drum bearing (WE3M26) and the drum slides (WE1M481) located at the top front of the drum.
To do that today, you would need to do the following for older dryers. Turn off the power by pulling the plug From the back remove the console. Remove the top Undo the two screws at the kick strip Carefully remove the front remembering there are wires. Short the wires together and tape them up. Put it all back together. For modern dryers. Some are surface mount and just pull out. Order the part, DON'T leave it like that! ..
