20 Most Recent
Speed Queen AES28AWF Electric Dryer Questions & Answers
Start switch hums but will not start dryer
The most common cause of the problem you describe is a broken drive belt. This doesn't mean it is the only possibility, nor that it is the issue you are seeing, but based on your short description, this could be the drive belt.
If you are mechanically inclined, you can replace it yourself, but if not, then contact your local appliance repair company to diagnose and replace whatever part needs it.
If you open the back panel and see that the drive belt is broken, then this could be an easy fix. Here is a link to the drive belt that fits your dryer: http://www.searspartsdirect.com/partsdirect/part-number/Speed-queen-Parts/Dryer-Parts/511255P/0026/250/Model-AES28AWF/1271/0151200?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=1101142P&diagramPageId=00009&productTypeId=&searchModelNumber=AES28AWF&subCompDesc=Motor/exhaust%20fan/belt&brandDesc=SPEED%20QUEEN&modelDesc=DRYERS&blt=11&shdMod=&keyId=7
Loud squealing noise
check the blower, something may be stuck in it or it may be broken, also check the 2 tank rotors that hold the tank in place, they may be damage or it may be a little bit of oil.
It wont dry
What is the model number? The one you posted is for a air conditioner.
The motor doesn't start; just hums.
I would have to agree that the motor is the problem, but before you replace it, check the bearing and blower fan to make sure they are in good shape. If the bearing is bad or the fan is blocked it could give you the same indication.
I have old style 4 prong plug,can i switch to 3
Yes. Remove old cord and install three prong with outer connectors to outer terminals on terminal block and middle to middle. There should be some kind of wire or strap that connects the middle terminal to the cabinet when you're done. A four wire setup should have removed the strap or wire but sometimes it isn't removed.
I put a new belt
Hi candhlooney...
Check,remove and lubricate your drum rollers and idler pulley, they may need cleaning and lubrication.
Please take time to rate me
The clothes wont dry till 4 hours. it take 5 hours
If your
dryer is not drying like it once did or if you just have nottaken the time to give yourself a
clean dryer in a long time then youneed to do that. At least once a year the
dryer cleaning should takeplace.
Lint build up in the
dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about
DryerMaintenanceheatman101
Speed Queen Heavy duty Dryer
The
cycling or operating thermostatis often the problem when a
dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about
why a clothes dryer will get too hot.
Clothes Dryergetting too hotheatman101
Dryerwill not heat. Heating element
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101;
Dryer will not turn on. Is there a fuse or a
either theres a rroken drum belt and theres a broken belt switch that opens the circuit if the belt breaks,or the therrmal fuse on the blower housings bad open and these two things will cause a dead dryer
