20 Most Recent
Binatone 100 Latitude Walkie Talkie twin Blackyellow Questions & Answers
Both phones are displaying out of range please advise
Walkie talkies talk to each other. Try transmitting (talk to each other) so they receive a signal first. Do it in the same room. The try for range. It is not much. Even for a GMRS radio, these are low power and short range. Under 2 miles, must be able to "see" each other.
How to stop it from picking up local taxi messages
In the US, those radios are in the GMRS band and difficult, although not impossible for a business to use. The whole idea of GMRS and FRS was for citizens to have radio channels to use. While GMRS frequencies need to be Licensed by the FCC for all users, businesses are not usually allowed and a Taxi should not be on those channels. You could call the FCC, make the Taxi company
prove they have a legal license.
Want battery-pack
In reviewing the product, it appears that the batteries are inserted directly into the radio. (no case or adapter to fit a battery module in) Buy re-chargeable 2500mh batteries.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
Yesterday
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
