20 Most Recent Maytag MGD9700S Gas Dryer Questions & Answers
2answers
Fires intermittently
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
11/12/2015 8:08:10 PM • Maytag MGD9700S... • Answered on Nov 12, 2015
Immediately after removing a dry load from my
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor. Also, check the blower for any obstructions. Sometimes a small article of clothing or a dryer sheet will get hung up and not allow the blower/motor to turn.
1/24/2011 2:28:23 AM • Maytag MGD9700S... • Answered on Jan 24, 2011
0answers
Dryer does not shut down
DOES THE TIMER TURN THE DRYER OFF IF YOU TURN IT MANUALLY, IF IT DOES YOU SHOULD REPLACE THE TIMER
8/10/2009 4:17:13 PM • Maytag MGD9700S... • Answered on Aug 10, 2009
How old is my appliance
This link provided by www.appliance411.com should be of assistance to you now and in the future.
http://www.appliance411.com/service/date-code.php
8/7/2009 1:46:18 PM • Maytag MGD9700S... • Answered on Aug 07, 2009
I bought two gas dryers(MGD9700SB0) for homes we
Good Morning.
I am sorry to hear about your problems.
Often a large appliance fault may be difficult to fix, and the technician may need more than one service before fixing the problem.
Maytag appliances are covered under warranty for the first two years, and you should be entitled to free parts and service until the problem is fixed.
What the technician did was reading error codes, and in your case a faulty timer board may have returned the wron fault code, leading the technician to replace the wrong part.
If you get charged for the service , or if you want a different technician you will better contact Maytag first, rather than contacting a Governative customer protection agency. Maytag can be contacted following indications on this page: Maytag Contact Us.
Best regards.
7/22/2009 12:07:13 PM • Maytag MGD9700S... • Answered on Jul 22, 2009
Our maytag dryer dries sometimes. It may leave
It turns out it was a clog in the vent. We purchased a new vent kit and the clothes dried properly.
Thank you so much.
7/18/2009 7:00:45 PM • Maytag MGD9700S... • Answered on Jul 18, 2009
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
7/5/2009 2:19:25 AM • Maytag MGD9700S... • Answered on Jul 05, 2009
Maytag Atlantis MDE6200AYW dryer. The buzzer won't shut off?
THE BUZZER WON'T SHUT OFF ON MY MAYTAG ...
JustAnswer https://www.justanswer.com > Appliance Repair Jul 21, 2017 - The way it works is that power from the heater goes to the motor so that the heater can't heat unless the motor is running. 1 answer ยท Top answer: The buzzer is not actually controlled by the timer. It's controlled by the centrifugal switch ... ..
2/20/2024 5:37:54 AM • Maytag Dryers • Answered on Feb 20, 2024
Maytag Dryer Model MGD5630HW3 Buzzes when starting a cycle and wont start the drum.
bad start up capacitor for motor
2/10/2024 7:57:59 AM • Maytag Dryers • Answered on Feb 10, 2024
Maytag 5000 series steam dryer. It won't start. it keeps flashing F01. What does that mean?
Question edited for clarity. Question moved from Misc Category. F01 is a very straight forward error and it means that your dryer has detected a short in the main relay power control board mounted to the left side wall under the top panel of the dryer. Oct 19, 2018
Our Maytag 5000 series dryer is showing an F01 error code.
F01 - Error Code - Dryer
Maytag https://producthelp.maytag.com > ... > Starts with F Dec 14, 2019 - Possible Solutions. Power unit down by turning off the circuit breaker(s) for one (1) minute. Power unit up by turning on the circuit . ..
2/1/2024 4:20:32 AM • Maytag Dryers • Answered on Feb 01, 2024
How do you light a pilot light on a Maytag dryer
most likely has hot surface ignitor, does not have free standing pilot.
1/12/2024 3:58:56 PM • Maytag Dryers • Answered on Jan 12, 2024
Where is the pilot light on a Maytag dryer
what is the model number? free standing pilots have been gone for several years. Google your model number and include parts. This will give you sites that sell parts. You most likely have and hot surface ignitor.
1/12/2024 3:57:12 PM • Maytag Dryers • Answered on Jan 12, 2024
What is the electrical capacity of Maytag MDG9700BWW?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=the+electrical+capacity+of+Maytag+MDG9700BWW%3F Then check related searches MOTOR: 1/4HP,120 volt,60 Hz,single-phase,thermally protected against overload,auto-reset. EXHAUST:Use a minimum of 4"(10.2 cm) diameter rigid aluminum or galvanized steel duct. Never use plastic,nonmetal or combustible duct. HEAT SOURCE/ELECTRICAL REQUIREMENTS: Electric model- 5,300 watt nichrome helix coil; 240 volt,AC,60 Hz; 30 amp fuse. Gas model-Single port burner with automatic electric ignition; 22,000 BTU/hr. 15 amp fuse. Self-adjusting valve automatically compensates for variation in gas pressure. WEIGHTS (Crated/Uncrated):
12/17/2023 1:41:53 AM • Maytag Dryers • Answered on Dec 17, 2023
What dose it mean F07 Maytag dryer
The F70 indicates a communication error code between the main control on the top left and the user interface on the front. Unplug the machine and remove the top. Check the connection on the board in the white plastic housing on the top left. Next check the connections on the board on the front.
12/4/2023 9:19:04 PM • Maytag Dryers • Answered on Dec 04, 2023
Maytag MGD9700S Gas Dryer Logo
14 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
immediately after removing dry load from
  • Dryers
