20 Most Recent Bosch Nexxt WTMC3321US Electric Dryer Questions & Answers
Not sure if this will address the problem but it maybe worth a try. We also had problems with our Nexxt dryer starting. We found the problem was with the start/stop button; it was not making contact with the mini-switch. Used some hot glue under the lever that makes contact with the mini-switch. Put it back together and works great again. Saved about $260 on new control panel. Removing the control panel was pretty easy for a DIYer.
Unplug the dryer.
Remove the four screws that hold the panel in place. They will be hidden under caps on the housing, Pull off the panel. Be careful because the wires will prevent you from pulling it entirely off but you can pull it from the right corner up and flip it on its back side to expose the back of the panel.
The white wire guard will have to be removed. The wire ties holding the wires to the guard will have to be removed by cutting the ties. Replacement wires ties can be purchased at any home improvement store. Remove the control panel by pushing the plastic clips in that hold it to the housing. There should be 6 and two plastic clips on the right center of the panel. If done right it will easily pull off. If force is needed one or more of the clips have not been disengaged. Do not force it because it is made of plastic and will break.
Once the control panel is removed from its housing, the start/stop button can be identified-last one either on the right or left (can
Bosch Nexxt... | Answered on Dec 07, 2018
I suggest you find someone to "get inside" the machine drum and find out what is damaging the clothes. I could not find the machine in "Sears Parts" to look at the drum. (They have pictures for most all US machines). I am not sure the drum might not need to be removed to repair it. There should be something there that is "snagging" the clothes and could be sanded down or smoothed somehow. If it has removable "paddles" to tumble the clothes, sometimes one could come loose and need tightening. I have seen heavy objects like large tennis shoes loosen a paddle.
Be blessed.
Bosch Nexxt... | Answered on Sep 20, 2015
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Bosch Nexxt... | Answered on Nov 05, 2014
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Bosch Nexxt... | Answered on Nov 23, 2013
Hi Frank Liles..
Here are a few causes and things to check
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork .
This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Bosch Nexxt... | Answered on Oct 18, 2012
Your exhaust vent pipe could be getting restricted. Make sure it is clean and free flowing.Make sure your screen is clean, and also the ventilation port in it leading to the screen. The port could also be restricted.
Bosch Nexxt... | Answered on Sep 03, 2011
Bosch Nexxt WTMC3321US Electric Dryer Logo
45 questions posted
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dryers
  • Bosch Dryers
Most Popular Question
limit thermostat
  • Dryers
