20 Most Recent CorningWare SC60 Slow Cooker Questions & Answers
2answers
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
4/13/2024 10:33:18 AM • CorningWare SC60... • Answered on Apr 13, 2024
I'm looking for the manual
Couldn't find a manual but here's how you can set the time and temperature: http://www.ehow.com/how_6496690_set-timer-corningware-slow-cooker.html Hope that helps.
4/30/2016 7:35:56 PM • CorningWare SC60... • Answered on Apr 30, 2016
Window displays 0 hours and will not change temp is warm and won't change
Try resetting by holding down the start button for a few seconds
11/29/2015 4:06:13 PM • CorningWare SC60... • Answered on Nov 29, 2015
NEED A REPLACEMENT GLASS LID FOR CORNINGWARE SC-60 SLOW COOKERW
I have this item if you want, I can send it to you. My slow cooker no longer works.
7/12/2015 5:50:03 AM • CorningWare SC60... • Answered on Jul 12, 2015
Broke my glass lid want
I need a glass replacement lid for a Corningware crockpot model
SCO-150 It is 120 vac 60 Hz 34OW. Thank you, Grace Brown.
7/12/2015 5:18:44 AM • CorningWare SC60... • Answered on Jul 12, 2015
manual
Need replacment lid for corningware slow cooker SC 6
Contact the manufacturer.
8/10/2014 3:12:56 PM • CorningWare SC60... • Answered on Aug 10, 2014
0answers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting. May 11, 2010
11/11/2013 8:20:31 PM • CorningWare SC60... • Answered on Nov 11, 2013
I broke the bowl that
would lining the inside with aluminum foil work for a tempoary on warm setting
11/2/2013 4:01:03 PM • CorningWare SC60... • Answered on Nov 02, 2013
CorningWare SC60 Slow Cooker Logo
108 questions posted
Top CorningWare Crock Pots & Slow Cookers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
ADMIN Eric
ADMIN Eric
Are you a CorningWare Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
View Most Popular
  • CorningWare Crock Pots & Slow Cookers
Most Popular Question
need glass replacement
  • Crock Pots & Slow Cookers
