20 Most Recent Sunbeam AW24CR3FHUE Air Conditioner Questions & Answers
You can order the parts from this site
http://www.searspartsdirect.com/partsdirect/part-model/Wintair-Parts/Room-air-conditioner-Parts/Model-AW24CR3FHUE/3305/0904032/50031430/00001?blt=06&prst=0&shdMod=AW-24CR3FHUE
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Sunbeam... | Answered on Jul 29, 2015
When you turn it on, do you hear the compressor come on? Make sure the controls aren't set to fresh air or vent.
Sunbeam... | Answered on Jun 01, 2010
Clean your coils and replace your air filter.
Sunbeam... | Answered on Aug 24, 2009
Generally means u have a bad connection at the wall or at the control module. Disconnect everywhere u can and reconnect
Sunbeam Heating... | Answered on Sep 09, 2019
Try unplugging the power cord from the wall socket and check that the connection to the blanket is good and not loose. Then plug back into the wall socket and switch on. If error still occurs then there may be a problem with the blanket.
Sunbeam Heating... | Answered on May 17, 2019
My sunbeam XL heating pad started blinking and I couldn’t figure it out. I Unplugged a couple of times and still it kept flashing. After hours of reading post, I did what wpart suggested and now it works normal again..... I kept pushing th on off button while plugged in, I unplugged it while still hitting the on off button, I plugged it back in while still hitting the on off button annnddddd drum roll please!!!!!! It started working properly! Thanks wpart, your the MVP and award goes to you!
Sunbeam Heating... | Answered on Feb 05, 2019
If you have the same heater i do then in between the elements at the bottom there is a safety swith that bends when it heats up and breaks the connection Dont mess with it plugged in it will shock the hell out of you but if you bend it down it wont be able to lift off the circut and will stay running untill you turn it off
Sunbeam Heating... | Answered on Dec 29, 2018
Wires probably damaged inside. Be carefull, I had one cought on fire. Dont like this things ever since
Sunbeam Heating... | Answered on Dec 28, 2018
unplug replug blanket to control connectors plug back in
this will continue to happen on these blankets you will have to reset these blankets again and again (chinese junk)
Sunbeam Heating... | Answered on Dec 22, 2018
http://www.electricblanketinstitute.com/blanket-or-comforter-on-top-of-electric-blanket.html
Sunbeam Heating... | Answered on Dec 10, 2018
Sunbeam AW24CR3FHUE Air Conditioner Logo
7 questions posted
Top Sunbeam Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Heating & Cooling
Most Popular Question
need fan blade sunbean aircondition
  • Heating & Cooling
