20 Most Recent Kaz Honeywell Hepa Air Cleaner (50250) Air Purifier Questions & Answers
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Kaz Honeywell... | Answered on Jun 14, 2016
Check to see if there is power getting to your device. If it is a 110-volt unit, plug a lamp or other device into the same outlet the device is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet. If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas: Wiring (Inspect for any broken or burnt wiring) Selector switch Control board Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Take care.
Kaz Air... | Answered on Oct 10, 2010
HOME IMPROVEMENT STORE PROBABLY IN ELECTRICAL DEPT
Air Purifiers | Answered on May 13, 2020
Pull off the front panel and look at the upper right, you will see two holes. One on top is the size of a pencil, and one below it the size of a dime. Use a paperclip, pen tip, ect and push the reset button in the center of the dime sized hole.
Air Purifiers | Answered on Mar 18, 2020
You would have to pull the ballast transformer out.
Pull the light fitting out.
Fit a new socket.
Run the mains wires that went the ballast transformer to the new socket.
Air Purifiers | Answered on Jan 10, 2020
Support at Guardian
https://www.guardiantechnologies.com/support
From your previous question: the Replace HEPA filter light wont go off.
Note: When you add information to a question, please use the Comment or Edit feature to add it to the same question, rather than opening a new question, because the new one has no link to the older one.
Air Purifiers | Answered on Nov 04, 2019
Check to see if there is a crack in the ceramic plate. If there is any type of disturbance where the metal is glued to it or you don’t have both leads on the metal it will not work
Air Purifiers | Answered on Oct 26, 2019
Where can one get a new bulb ballast for the UV801?
Air Purifiers | Answered on Jul 17, 2019
Kaz Honeywell Hepa Air Cleaner (50250) Air Purifier Logo
Popular Tags
6 questions posted
Top Kaz Air Purifiers Experts
Marvin
Marvin
john h
Are you a Kaz Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
Kaz Air Purifiers
  • Kaz Air Purifiers
Most Popular Question
honeywell hepa
  • Air Purifiers
