20 Most Recent
Moffat MOF-E35E85HLD8 Turbofan Convection OvenProoferHolding Stacked Questions & Answers
Internal breaker trips
You will need to get an ammeter to see how many amps are being drawn by the motor. You can purchase an inexpensive meter at home depot or Radio Shack, The meter should be clamped around one of the wires from the motor. If the amps are more than the internal breaker, the motor is bad (even a new motor) if the amps are lower than the internal breaker, the breaker itself is your problem. You should also verify that you have the proper voltage motor and input to oven. Hope this helps
5/1/2009 4:55:54 PM •
Moffat...
Answered
on May 01, 2009
How can I remove door?
Hi Tammy:
Many of the older stoves used a similar door hinge system.
When the door is fully opened it can be removed in the following way.
It's much easier with two people.
With one person on each side, lift near the hinge (closest to the stove) then pull away from the stove and at the same time, lift the handle end of the door.
There is a tab and a notch on the hinge arm that has to slide past the retainer.
To re-install, the hinge has to be set for the "door open position".
Slide the hinge arms into the slot so that the tab and slot engage in the correct positions.
Hope this helps.
Cheerfuls. .
5/11/2021 8:17:19 PM •
Moffat Ovens
Answered
on May 11, 2021
Moffat oven doesn't heat .The elements don't turn red
Check the oven fuse. If that's OK, unplug it from the power supply. Remove the screws holding the element to the oven and pull it carefully back away from the oven wall. Connect your VOM test leads to the 2 terminals (meter set to at least 250Vac). Make sure the leads are not touching any metal parts of the oven and they are not touching the element. Plug oven in and turn the oven on. Do not touch the oven during testing. Reading 220 - 250 Vac power is OK. Element is bad. Reading lower then 220 or none at all no power getting to element, need more testing to find the problem. Be careful, and use common sense when working with and around electricity.
2/5/2015 1:11:06 AM •
Moffat Ovens
Answered
on Feb 05, 2015
