20 Most Recent Holmes Products Holmes HPF1151MK-UM Outdoor Stand Fan Misting Kit Stand (Pedestal) Questions & Answers
Am I the only one reading that the OP is asking about a box fan.....never seen lights on a box fan...
I'm also trying to bypass the 3 speed knob on my box fan. Is it possible? I ask because preliminary testing of holding wires to each other turned the blade but began getting hot and with enough time I'm sure would've been a pretty nice fire.
Holmes Products... | Answered on Jul 18, 2020
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Holmes Products... | Answered on Jun 09, 2017
Just a thought
If you find a junker fan try the switch off of it. Quite often they will work. Sometimes different makes the switches are interchangeable.
Holmes Products... | Answered on Feb 15, 2015
yep and the best stuff is NRP zoom spout oiler part# D01.. and its made in the USA !.. jay the pool pump motor repair guy Longwood Florida
Holmes Products... | Answered on Sep 03, 2014
Take front of the fan cover off hold the back of fan the push and pull out on fan blades from the center. If blades move in and out .The bearings on motor shaft worn out. If no movement try to blow out the motor with compressed air reassemble then try.
Holmes Products... | Answered on Jul 24, 2014
Should be three clips that fold over the outer cover pry up clips with a screw driver.
Holmes Products... | Answered on Jul 21, 2014
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Holmes Products... | Answered on Jul 16, 2014
Holmes Products Holmes HPF1151MK-UM Outdoor Stand Fan Misting Kit Stand (Pedestal) Logo
Popular Tags
4 questions posted
Top Holmes Products Dryers Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Anthony Ulrich
Anthony Ulrich
Level 1 Expert
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • Holmes Products Dryers
Most Popular Question
need 3 speed fan switch holmes stand fan
  • Dryers
