20 Most Recent Haier 11000 Btu Portable Ac Air Conditioner Cpf11xcl-ew Questions & Answers
there could be multiple thing that could cause this if you are lucky it is in the electronics of the unit but with these portable room air conditioners just like the old window units the tend to get refrigerant leaks easily due to the constant moving around and they do not come with service ports so it could be a low pressure safety switch shutting the unit down find the wiring diagram either on the unit in the owners manual or online if you don't understand it see if you can find someone local that does to test the electrical components if all are good then unfortunately it would be cheaper to purchase a new unit than to have this one serviced
Haier 11000 Btu... | Answered on May 31, 2016
Nothing is broken and you don't need to print off anything or order anything. There is simply too much water in the drainage tank.
Unscrew the spicket at the rear bottom of the units and pull out the plug. Let the water drain. It will work again immediately.
Replug. Rescrew. Enjoy.
Haier Heating &... | Answered on Jul 12, 2020
the flashing red light indicates that the water collection tank is full
Haier Heating &... | Answered on Jun 05, 2020
possible start up capacitor for fan or compressor bad or bad motors
Haier Heating &... | Answered on Dec 24, 2019
Really not enough info to give a good answer yet... was it cooling your home good before you switched to heat? If it wasn't, then most likely your system is low on refrigerant... when it is suppose to be on, check to see that your outdoor unit is coming on, if it is on and the outside unit looks like a block of ice or starting to ice over, the defrost control board has failed and needs replaced.. hope that helps
Haier Heating &... | Answered on Oct 05, 2019
Their a sealed system..only way is to install a piercing valve...good luck they usually always leak after that... but it won't fix the problem you need to find the leak..good luck
Haier Heating &... | Answered on Jul 15, 2019
make sure to set time on unit then program
Haier Heating &... | Answered on Jun 30, 2019
E7 normally no 120 volt current to unit
Haier 11000 Btu Portable Ac Air Conditioner Cpf11xcl-ew Logo
3 questions posted
Top Haier Heating & Cooling Experts
Tom Chichester
Zoom-The Computer...
Thomas Woodburn
Thomas Woodburn
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Heating & Cooling
Most Popular Question
cpf11xcl ew when put in cool mode will
  • Heating & Cooling
