20 Most Recent
Thermador FREEDOM® T36IT70CNS Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
Thermador Ice Bucket grey tab broke?
If the grey tab on your Thermador 42-inch built-in refrigerator's ice bucket broke, and you're unable to pull the ice bucket out for cleaning and drying, here are a few suggestions to try:
- Use a flathead screwdriver: Insert a flathead screwdriver into the slot or opening where the grey tab used to be. Apply gentle pressure to push or lift the ice bucket enough to release it from its locked position. Be careful not to damage the surrounding components or scratch the interior of the refrigerator.
- Thaw the ice: If the ice bucket is iced up and causing difficulty in removal, try thawing the ice by turning off the ice maker or adjusting the freezer temperature slightly higher. Allow the ice to melt, which should make it easier to remove the ice bucket. Be sure to place a towel or tray underneath to catch any melting ice or water.
- Contact Thermador customer support: If the above methods do not work or you are uncomfortable attempting the repairs yourself, it is recommended to contact Thermador's customer support directly. Provide them with the model number (T42BD820N810) and explain the issue with the broken tab and the difficulty in removing the ice bucket. They will be able to provide further guidance, including potential solutions or arranging for a service technician to assist you.
6/28/2023 2:45:20 AM •
Thermador...
Answered
on Jun 28, 2023
Thermador T30IF70NSP/10 Ice Maker not working properly
please lower the rate of ice being dispensed to see if the problem is overcome or you can lower the temperature of the freezer. I would try each separately and check results before combining the two methods. Thank you.
9/29/2022 2:55:57 AM •
Thermador...
Answered
on Sep 29, 2022
Water and ice control panel not working
ahhhh... for me, it is a bad appliances and need to check ( if it is new, you have to return it to the owner and replace a new one) to the technical experts.... if you want to...
10/29/2021 3:59:55 PM •
Thermador...
Answered
on Oct 29, 2021
