20 Most Recent Honeywell RTH230B 5-2 Day Programmable Thermostat Large Questions & Answers
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Honeywell... | Answered on Oct 03, 2019
Hello, the snowflake flashing is a (supposed to be) 5 minute delay to prevent short cycling of the compressor. This delay can sometimes get stuck thus requiring replacement. To test , remove top of thermostat to where you can identify wires and terminals. Have someone stand near the ac unit for this test, and then take a wire or paperclip and briefly touch Rc to Y. This should start the outdoor unit. R to G will start the indoor fan
Honeywell... | Answered on Jul 06, 2019
Contact Honeywell and see if there is some sort of reset for unit.
Honeywell... | Answered on Mar 03, 2016
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Honeywell... | Answered on Feb 03, 2015
It could be the breaker is tripped or the blower is not getting power. Check your transformer to make sure you are getting 24 volts going to the fan relay sequencer and make sure you check your capacitor that is connected to the fan as well. sounds like a minor electrical hiccup. Also check your thermostat wires and pay close attention to anything marked w1 or w2 as these are the terminals that control the heating part of your system.
Honeywell... | Answered on Dec 01, 2014
means it is running in the cooling mode a flame means heating
Honeywell... | Answered on Sep 16, 2014
You have to take the cover off and get inside and unhook a wire. You may have 3 wires unhook 1 and if that doesn't turn it off hook it back up and unhook the next. One of them will turn it off!! Then go to the hardware and get another thermos!! You won't get a shock or anything cause it's not hooked up to any power source, they are just sensor wires. I don't know much about Honeywell, I just know I don't like their thermos. Had one once and had nothing but trouble w/it !!
Honeywell... | Answered on Jul 27, 2014
Please go to the link and check graph "2.5 Installing the Batteries". Its really easy so it should be a piece of cake.https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf
Honeywell... | Answered on Mar 31, 2014
don't know but honeywell technical support may know
https://www.honeywellstore.com/customer-service/contact-us.htm
check if it has a safety switch in the base as it may not be making contact with the surface the fan is sitting on.
It has a timer maybe cause ?
if not in usa then go to honeywell in your country and then look for help at bottom of web site.
Honeywell... | Answered on Jun 01, 2020
Replacement batteries could be defective or installed incorrectly
Honeywell... | Answered on May 23, 2020
https://www.youtube.com/watch?v=RtgN-tM9Al0
Honeywell... | Answered on May 03, 2020
Robert Shaw 9500 manual
Honeywell... | Answered on Apr 29, 2020
get in a repair person and send the bill to the land lord. He has no legal right to interfere in your operation of your equipment
Honeywell... | Answered on Mar 16, 2020
There is a battery inside the thermostat. No one seems to know about this battery. If the battery is dead thermostat won't work. Pop thermostat apart, test battery and replace.battery. I am not 100% sure this is your problem, for your thermostat, but I have come across this problem before. Good Luck Friend.
Honeywell... | Answered on Feb 24, 2020
Honeywell RTH230B 5-2 Day Programmable Thermostat Large Logo
Popular Tags
17 questions posted
Top Honeywell Heating & Cooling Experts
Paul Carew
Sean
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Heating & Cooling
Most Popular Question
replaced battery honeywell rth230b heat
  • Heating & Cooling
