20 Most Recent Comfort Zone CZ-530 Compact Heater Questions & Answers
any qualified electrician or repair center will be able to do the job
Comfort Zone... | Answered on Dec 03, 2017
thermal switch bimetallic strip inside has got too hot turn off power slide small screwdriver between the two halves and gently tease up 3mm
Comfort Zone... | Answered on Feb 06, 2017
You mean no fan ? Probably needs some oil on the motor. Use non-flammable Zoomspout oil from ace hardware.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Comfort Zone... | Answered on Oct 28, 2012
Heaters have
)Tip over switch If the heater is thermostatically controlled then what you may have is the thermostat cycling just as a central heating system in your home. When heater reaches the temp you set it shuts off, then comes back on when temp drops several degrees below setting. Yes, It is normal. Ned
2)Thermostat
Comfort Zone... | Answered on Dec 18, 2010
If there are only two wires going to the switch you can unplug the heater and strip about 1/2 inch of insulation off of the wires and twist them together. Use a wire nut or electrical tape to protect connections.
If you can't find the right replacement switch you can use a simple toggle switch in it's place. Or just unplug it when you're done using it. I hope this helps you. Thanks.
Comfort Zone... | Answered on Dec 08, 2010
You should change its plates.
Comfort Zone... | Answered on Dec 20, 2009
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Comfort Zone... | Answered on Jan 18, 2009
The red light probably is only showing that the unit has power to it and does not show if there is an internal breaker or fuse that is open.
Comfort Zone... | Answered on Sep 14, 2020
Hi.
Hold the two buttons on right with power on to reset it.
Good luck.
Comfort Zone... | Answered on Aug 20, 2020
I had a similar issue. It would cut off after approx 30 sec to 1 min. If the power shuts off or screen and lights go off most likely the problem is the thermal cutoff switch comonly called a thermostat. (Be Sure you are getting good air flow also check filter JIC) I found the problem but the parts in the systema are cheap off brand parts. Low quality circuit boards and soldering. The PN on the switch was unknown. Since I didnt know the cutoff temp I called the mfg which did not offer any parts, prints etc. This is an expensive throw away heater is basically the answer I recieved. My unit also had very low use as it is used as a supplimental heat ocassionally. Instead of tossing the unit I looked a little closer at the switch. I found 120 deg C stamped on one of the .25 QC terminals. On the front it is stamped 120/240V 16A. After a search I found the SRL250. It is a 250 deg F 15A 120/240VAC. (120 deg C = 248 deg F). It is 1 amp less which is fine as the 1500W unit should not draw 15 or 16 Amp. I now have the heater running again. You can find this part online or you local appliance parts house should have it. Or Cross ref to another mfg. Hope this helps.
Orig- 120/240VAC 16A 120 deg C (Open on Rise)
New - 120/240VAC 15A 250 deg F (Open on Rise)
Part# - SRL250
Comfort Zone... | Answered on Dec 29, 2019
If it is new, contact your seller for return or replacement under warranty
Manual
http://comfortzone-us.com/temp/CZ499R_manual.pdf
Does it have a reset button or a fuse that is burnt out?
Comfort Zone... | Answered on Dec 17, 2019
Comfort Zone CZ-530 Compact Heater Logo
18 questions posted
Top Comfort Zone Heating & Cooling Experts
Marvin
Marvin
Paul Carew
Muntejaya Ginting
Muntejaya Ginting
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Comfort Zone Heating & Cooling
Most Popular Question
heating wire come loose both top
  • Heating & Cooling
