20 Most Recent Uniden DECT1580 Cordless Phone Questions & Answers
Several manuals for the Uniden DECT1580 are available from Uniden support: http://www.uniden.info/download/ . The product documentation page is http://www.uniden.info/download/index.cfm?s=DECT1580 . The direct link to the English version of the owner's manual for one model in the series is http://www.uniden.info/download/ompdf/DECT1580-2om.pdf . This version came with 2 handsets; it is also sold with one handset or up to 4 handsets.
I hope this helps.
Uniden DECT1580... | Answered on Aug 14, 2019
What is phone system connected to ?
A land line ?
what sort of diversion ?
unconditional *21{phone number}# #21# to turn off unconditional
no reply / busy ? https://infinititelecommunications.com.au/network-feature-codes/
https://www.telstra.com.au/small-business/online-support/category/bundles/dot/where-can-i-find-a-list-of-feature-access-codes
Uniden Lands... | Answered on Oct 12, 2020
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Uniden Lands... | Answered on May 25, 2020
Call the phone provider you are using, (verizon, att, etc.) they can help you to reset the password.
Uniden Lands... | Answered on Mar 27, 2020
Hello Lynn:
Make sure the power cord is securely plugged into the telephone base. Plug the telephone base into a different working electrical outlet not controlled by a wall switch. Move the handset closer to the telephone base. It may be out of range. Reset the telephone base by unplugging the electrical power to the base. Wait for 15 seconds and plug it back in again. Allow up to one minute for the cordless handset and the telephone base to synchronize. Other electronic products such as HAM radios and other DECT phones can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Do not disturb or silent mode may have been enabled. Without the model number of your phone, I might miss one of the ways to re-enable ringing for your model. Make sure that the phone is in standby mode. Next, check if there is a DND button on the base for the cordless phone system. If the LED for the button is lit, press that button. You may need to hold the button; enabling Do Not Disturb requires a press and hold.
To disable silent mode, press and hold Silent on either the handset or the base. On the handsets, this may be the # key (below the 9). When you enable Silent Mode, you can get a prompt for how long you want the phone to be quiet. If you do not press any number key (other than 0), the Silent Mode will last until you disable it manually. You can then confirm the Silent Mode or it will be enabled after 5 seconds.
I hope this helps. In both modes, the answering system will automatically be turned on if it wasn't on before enabling the mode.
Uniden Lands... | Answered on Jan 30, 2020
message light
press menu
scroll to settings then to global settings press menu scroll to vmwi and press enter
scroll to yes , press menu then end
most started after changing to NBN
Uniden Lands... | Answered on Nov 10, 2019
Select the channel, press 0, press E
Uniden Lands... | Answered on Nov 06, 2019
You don't state if the unit is on charge when it happens, or if it is all the time. You also do not state what model, and Uniden makes hundreds of products. But, it is probably an inadequate load on the charger, which would mean the battery is toast.
Uniden DECT1580 Cordless Phone Logo
2 questions posted
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
uniden model dect1580 access detailed
  • Lands Phones
