The fridge relies on the freezer fan to supply it's air flow. If the unit is running and the freezer fan is not, then most likely it is the evaporator fan motor that has failed. You can access it by removing the inside back wall of the freezer. If you need help get me the complete model number out of the fridge and I can pull up the breakdown to help walk you through it.
if the fan run and does not freeze, possible compressor or compressor start kit. Start kits that a beating in stormy weather. Start kits consist of a relay, capicator and overload sensor. These 3 parts can be ordered seperately or a generic start kit with all the of these made in one. if the compressor is bad on a 10 year old freezer you might want to look at a new freezer
the first thing to check is open the freezer door while the unit is running.if you do not here the fan the it needs to be replaced.also check and see if there is any ice build up in the rear of the freezer if there is ice build up this will block the air flow into the fridge.then you should replaced the defrost timer. good luck i hope this helps you out
Coldspot 106. Model
This model refrigerator is a relatively small refrigerator. It is a Freezer on top model, and Sears documents lists this unit at 18.1 cu ft. I hope that answers your question about capacity.
I'm glad I could help. If you need anything else, just let me know.
In reality, when you buy a replacement, you buy by dimensions to fit the space not cubic feet of the old one. Go to Home Depot armed with a tape measure.
Turn it off by removing the wall plug for 10 minutes. This will do a power rest to the control electronics. This is a bottom mounted freezer, so cold air for the fridge is vented upwards by a fan. Make sure it is running and there are no ice blockages. Strangely they call the fan in the fridge an
Refrigerator Evaporator Fan Motor. The part is obsolete anyway.
If it normally says 4 for the fridge, that would be 4 degrees Centigrade, which means the freezer should show minus 18'C. Or 36'F Fridge / 0' F Freezer/
This shows all the parts.
https://www.searspartsdirect.com/model/3tradtge4f-000582/kenmore-79575004401-bottom-mount-refrigerator-parts
