20 Most Recent Pride Jazzy Select Elite Questions & Answers
Turn on Joystick and push horn twice, you are in locked mode. If this didn't work then turn Joystick on push gimbal forward until you hear a beep, then move the gimbal back until it beeps you are now unlocked. Gimbal= what you push to go left right forward or back on a joystick.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Pride Jazzy... | Answered on Apr 09, 2016
You are in locked mode. try turning the joystick on and pushing the horn twice. or if that did not work try turning the joystick on and pushing gimbal forward until it beeps and then back until it beeps. should be unlocked, scrolling up and down will stop and you can drive.
hi Kathy, sadly there isn't a easy way to do this and you really need someone skilled in working with the powerchairs. This can be a joystick fault however make sure all connections are a tight fit ...
If you're based in the UK please give me a ring as I carry out free testing ...
Regards
Rob.
Pride Jazzy... | Answered on Feb 17, 2016
As a quick fix yes you can but I wouldn't trust that but for a few miles at really low speed. Get a new tire asap!~
Pride Jazzy... | Answered on Dec 08, 2015
Hi Nancy , 4 Flashes There is a bad connection on the right motor. Check the right motor connections..
But did he check the brushes ?, did he check the wiring ?
Where are you based please ? ,if in the UK (not sure of US consumer laws ) demand your money back until sorted...
I have repair hundreds of those wheelchairs and normally it's a brush or wiring issue or joystick , motor problems are quite rare... a simple resistance check would confirm that ...
Regards
Rob...
Pride Jazzy... | Answered on Oct 14, 2015
The battery is not taking the correct charge and is in need of replacement. Put a brand new battery in there and the problemo will be gone!
Pride Jazzy... | Answered on Sep 02, 2015
then that is where we wouldve said to look
Pride Jazzy... | Answered on Jun 24, 2015
Look in your user manual in the trouble shooting section. I think its the solenoid brakes fault. Check the brake levers are in drive position or it can be the brakes need attention.
Error code for pilot plus see....
http://support.pgdt.com/Online-Diagnostics/Flash-Code-List/Pilot-Flash-Codes.aspx
Pride Jazzy... | Answered on Jun 16, 2015
No, they will stay flashing until you remove the charger/chord.
Pride Jazzy... | Answered on May 06, 2015
Your batteries are nearing replacement time. They are becoming incapable of holding a full charge.
Pride Jazzy... | Answered on Apr 29, 2015
First measure the voltage of the batteries at the charging socket of the joystick.
Pride Jazzy... | Answered on Nov 06, 2014
They require a programmer offered by the the manufacturer to make adjustments. You should contact a local Medical Company or go to Pridemobility.com for an authorized dealer near you.
Pride Jazzy... | Answered on Sep 21, 2014
hi, in the UK or US ?
Regards
Rob
www.gewizrepairs.co.uk
Pride Jazzy... | Answered on Jul 26, 2014
The throttle potentiometer error code is caused by a damaged or worn potentiometer. The fix for this problem is to replace the throttle potentiometer. The part is available from Pride based on the model and serial number. Hope this helps.
Pride Health &... | Answered on Jan 26, 2021
Your description suggests one or both of the batteries are sulphated - been allowed to remain partially discharged or even fully discharged for a few weeks or more.
Charge the batteries, allow them to stand for a few hours and connect a voltmeter. A healthy young battery should read 13/13.2 volts while an older battery that is still serviceable might only achieve 12.7. Much below this and the capacity will be much reduced.
If these are the sort of voltages you have, the charger is probably ok. Ride the scooter until the battery indicator shows recharge is needed and test the voltage again - if it has fallen considerably, at least one of the batteries is faulty.
Traction, semi-traction or deep cycle batteries are the only ones that should be used and cheaper batteries will serve for a time but rarely survive the warranty period.
Batteries that are discharged generate heat when recharged and it is the heat that shortens battery life. Batteries last longer if they receive a top-up charge after each use.
Never leave a battery in a discharged or semi discharged state...
Pride Health &... | Answered on Jan 14, 2021
Your local repair shop needs to repair the repairs done wrong.
Pride Health &... | Answered on Jan 07, 2021
1. Defective battery
2. Defective charger
Pride Health &... | Answered on Oct 29, 2020
This is how we managed to take of our seat.Ir takes 2 strong people to turn the seat whilst pressing the lever under the seat ,you will feel a quiet click,near the seat post this is the area that will allow the seat to be lifted of,might you no where I can find the vin chasis frame number and engine number,i have asked this question in a post sent today.
Pride Jazzy Select Elite Logo
16 questions posted
Top Pride Health & Beauty Experts
Marvin
Marvin
Mike
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
check wrench flashing 4 pause 4
  • Health & Beauty
