20 Most Recent
Whirlpool RF369LXPQ Electric Kitchen Range Questions & Answers
Whirlpool Electric Range Model #
Hello, Thank You for using FixYa. I will be helping you today.It means the door lock and door switch dont agree. Check the door switch does the oven light go on and off? does the door lock? It is either the door lock or oven door switch that controls the light.
Thank You and please rate my answer if it was helpful..
6/14/2011 12:37:25 PM •
Whirlpool...
Answered
on Jun 14, 2011
My electric range ha a f-5 on the digital diplay.
Hi
The error code F5 means you need to check the door/latch switch and replace the switch if its defective.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
7/7/2009 11:53:21 PM •
Whirlpool...
Answered
on Jul 07, 2009
Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
1/30/2009 5:43:39 PM •
Whirlpool...
Answered
on Jan 30, 2009
Oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
11/13/2008 1:13:37 PM •
Whirlpool...
Answered
on Nov 13, 2008
Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
11/2/2007 12:44:33 AM •
Whirlpool...
Answered
on Nov 02, 2007
Whirlpool gas range diagnostic code E6 46 (cannot find this error code combination anywhere)
E6 46 is a diagnostic code for a Whirlpool gas range. This code indicates that there is a problem with the oven temperature sensor. The sensor measures the temperature inside the oven and sends this information to the control board. If the control board detects a problem with the sensor, it will display the E6 46 error code.
To troubleshoot the problem, you'll want to do the following:
- Check the wiring: Make sure that all of the wires connected to the oven temperature sensor are secure and not damaged.
- Check the sensor: The oven temperature sensor is located in the back of the oven, near the top. Make sure that the sensor is properly seated in its socket and that it is not damaged.
- Check the control board: If the wiring and sensor appear to be in good condition, the control board may be the cause of the problem. You'll want to check the control board for any visible damage or loose connections.
If you are unable to find the problem, I recommend having a qualified repair technician diagnose and fix the issue for you. Electrical issues can be complex and it's important to address them promptly to prevent further damage.
1/8/2023 1:32:12 AM •
Whirlpool...
Answered
on Jan 08, 2023
What is F9 code for whirlpool stove
The F9 error code on a Whirlpool stove typically indicates a problem with the oven temperature sensor. The oven temperature sensor is a device that measures the temperature inside the oven and sends this information to the control board. If the sensor is not functioning properly, it can cause the control board to display the F9 error code.
To troubleshoot the problem, you can try the following steps:
Check the oven temperature sensor: Make sure the sensor is securely connected to the control board and not damaged. You can also check the resistance of the sensor using a multimeter to see if it is within the specified range.
Check the wiring: Make sure all the wiring for the oven temperature sensor is securely connected and not damaged. Check for any frayed or damaged wires, and repair or replace them as needed.
Check the control board: If the oven temperature sensor and wiring are in good condition, the problem may be with the control board. You can try resetting the control board by unplugging the stove and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, you may need to take the stove to a professional appliance repair shop for further evaluation and repair. They will be able to diagnose the problem and recommend the necessary repairs.
12/24/2022 4:37:31 PM •
Whirlpool...
Answered
on Dec 24, 2022
