20 Most Recent Jensen Jcr220 Clock Radio With Time Projection Questions & Answers
Turntable on my Jensen JTA-460 is slow. I have replaced the belt and made sure table was lubricated. No change. Can not find a way to adjust speed of table.
Check the belt is fitted correctly. If it is not it will affect the speed. If the speed is slow on both 45 and 33 rpm, then it could be the motor. Sometimes there are speed presetts at the none shaft end of the motor. If it doesn't look like the motor has any built in electronics in it, then look to the turntable power supply look for faults in that.
6/5/2021 2:32:13 PM • Jensen Audio... • Answered on Jun 05, 2021
Why cant i play mp4 video files on my jensen vm9115 usb?
Probably incompatibility
11/19/2020 12:22:52 AM • Jensen Audio... • Answered on Nov 19, 2020
I need instruction Manual Jensen JCR 280 under the Cabinet
To set stations, press set button on far right then search station then press number station is to be set.
1/15/2020 6:35:06 AM • Jensen Audio... • Answered on Jan 15, 2020
Can someone provide the Specs on 'old' Jensen CS 315 speaker, 3 way floor standing. I have 3 units in mint condition.
Hi Tom- I found this link regarding Jensen CS 315 speaker specs. Click on "See More" for further information. https://picclick.com/JENSEN-CS-315-3-WAY-MONITOR-STEREO-SPEAKERS-8-184010428853.html Hope this helps.
1/9/2020 5:51:07 AM • Jensen Audio... • Answered on Jan 09, 2020
Jensen JCR-315 manual
5/31/2019 2:24:55 AM • Jensen Audio... • Answered on May 31, 2019
2answers
I have a Jensen QX80 Subwoofer which has stopped working properly. When I power it up, it turns on and makes a buzzing noise, I could smell a burnt electrical smell when it first occurred. Any advice?
Bill, Sorry that I have to be so general in answering this question. If there is a burnt smell associated with the occurrence of the problem, then that would point to a fault most likely in the audio output circuit. If the unit blows a fuse, then I tend to think that it is in the power supply of the internal amplifier. Either way, service is needed for the unit. It is best to disconnect the unit from your sound system and try to find someone qualified for this repair.
3/29/2019 10:57:27 PM • Jensen Audio... • Answered on Mar 29, 2019
Can I input a Satelite radio receiver into my Jensen JSM 96; ..................If so how?
Does your Jensen have the AUX inputs on the back or front? You would need to find a Satelite radio with the Outputs that will plug into the AUX Inputs. Some radios have a special input connections for Satelite radios, so check the Manual.
1/25/2019 4:15:02 PM • Jensen Audio... • Answered on Jan 25, 2019
How to clean the tuner on Jensen JCR-560?
They make a special spray for that purpose.
4/6/2018 8:13:43 PM • Jensen Audio... • Answered on Apr 06, 2018
How to set the time on a Jensen JR-175A clock radio?
Page seven of a similar model manual http://www.spectraintl.com/images/stories/pdf/jn/UM/JCR-310_EIB.pdf 1. With the unit in Standby mode, press and hold the TIME SET button for about 1 second 2. Press the (two right triangle / two left triangle buttons) to adjust the hour. 3. When the correct hour is selected, press the TIME SET button to confirm and the "minute digits" will begin to flash on the display. 4. Press the (twwo right triangle/two left triangle buttons) to adjust the minutes. 5. When the correct minute is selected, press the TIME SET button again to complete the setting.
3/2/2018 4:07:55 PM • Jensen Audio... • Answered on Mar 02, 2018
Jensen Jcr220 Clock Radio With Time Projection Logo
4 questions posted
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Audio Players & Recorders
Most Popular Question
jensen jmc 1200bk cd player will not
  • Audio Players & Recorders
