20 Most Recent Sabrent Serial ATA (SATA) 1 External + 2 Internal Port + 1 IDE 133 port RAID PCI Card (SA-IDE88) Storage Controller Questions & Answers
Go through the prompts,then have your computers compatability wizard check first.Then look for the drivers properties.Then see if,after it installs the computer still doesn't read the disc then write or call microsoft.Or ask them online about this.
Sabrent Serial... | Answered on Feb 15, 2010
Problem solved. There are 2 sets of jumpers on this PCI card. By deault they are set at 1-2 on both jumpers. So I changed them both to 2-3, reinstalled the card, restarted my PC and WoW!!!
There it was... working and recognizing both the HDD.
Thanks anyway and I hope that my answer gets posted as public so others can learn from my adventures... jejejeje.
Thanks FixYa!!
Sabrent Serial... | Answered on Jan 18, 2010
Follow this link and choose Serial ATA from the dropdown list.
Then choose SA-IDE88 and the driver download will start.
http://www.sabrent.com/#section=Drivers&itemName=&itemID=0
Sabrent Serial... | Answered on Oct 07, 2009
Hi there.
You will need to open your BIOS settings, and change your boot sequence/priority so that it includes PCI cards. Save and exit, and see if it then boots.
If you need anymore help, or need me to clarify anything, I'll be happy to help.
Tim
Sabrent Serial... | Answered on Apr 28, 2009
you should be able to chose that drive in the setup (bios) select it to boot first..
Robert
Sabrent Serial... | Answered on Feb 06, 2009
yes, photos 101
I can answer most questions if the level.
first off no photo editor does all formats of all camera's made.
that is a fact. some come close with $300 software. you don't have.
my guess is your camera uses the great TIFF format.
no PC STATED, NOR OS VERSION, SO I CAN KNOW WHAT
VERSION OF PAINT YOU HAVE.
Windows 10 paint does tiff,giff,jpg and even bmp so it's not that.
first off when moving photos off any camera made.
look to see what the file names are the extensions.
dm0101.tiff is TIFF.
dm0101.bmp is BMP.
see, ?
the see if it is too big, many editors of photo can not do 50foot wide photos as some pro camera's can do. (CANON top brand)or NIKON.
the camera has settings mode, set it to JPG or PNG mode
and any editor can edit those.
sabrent product
my wild wild guess, next this name above is 3.5" extrernal USB flopy diskette reader
that say your relic 2000 year, SONY 3.5" camera created .
(yes they did that back in the day, )
and now you connect the 3.5" Sabrent and you can copy said
fails ok, but failed to note the full file names.
to see extensions you must tell nasty windows you want to.
yes windows is PAIN, in this one regard.
so you go to control panel.
click file explorer options.
then click VIEWS TAB.
then click and uncheck hide file exemptions. (leave OS extensions alone below)
after doing this great act (we do this step one new PC or OS)
we can see what kind of photo is for the first time.
then post that and we can edit anything
or get GIMP, for free for windows.
Sabrent... | Answered on Apr 15, 2019
go to contol panel, devices and find sound,look for the drivers for this,Sabrent and remove them and reinstall them...which probably means downloading the from Sabrent web site unless you have a disc
Sabrent... | Answered on Sep 30, 2018
Plug it into a USB port and it should be seen by Explorer and listed as an external drive.
Sabrent... | Answered on Jan 25, 2018
Probably incorrect type of drive expected by your USB case.
Sabrent... | Answered on Nov 27, 2017
Not knowing which product you need a driver for, I recommend going to there website and click on support;
https://www.sabrent.com/support/
this will assist you with most questions you have.
Sabrent... | Answered on Nov 07, 2017
Usually you can follow the 30:30:30 rule. Turn off and hold the reset 30 seconds, then still holding the reset turn on and wait 30 seconds more, release and the unit will reboot in 30 seconds.
Sabrent... | Answered on May 09, 2015
Your floppy disk drive may be defective. Also, Some floppy drives are manufactured differently. Your best bet is to find another floppy drive to read your floppy disk. You can try to take it to the nearest computer store and ask them to read it for you. If they can read it at the computer store? The Sabrent drive you received if bad. If they cannot read it the floppy is bad. If the floppy is bad you can try to download free data recovery software to attempt to recover your data, files etc. Good luck
Sabrent... | Answered on Aug 19, 2014
The floppy disc drive doesn't show under "computer" in the left hand column, but I've found that by clicking on "computer" it's listed in the main window. From the "Microsoft Community"
Sabrent... | Answered on Jun 23, 2014
Sabrent Serial ATA (SATA) 1 External + 2 Internal Port + 1 IDE 133 port RAID PCI Card (SA-IDE88) Storage Controller Logo
6 questions posted
Top Sabrent Computers & Internet Experts
Colin Stickland
Colin Stickland
ChinthakaJ
ChinthakaJ
Joel Rodriguez
Joel Rodriguez
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sabrent Computers & Internet
Most Popular Question
2 320gb sata drives connected pci
  • Computers & Internet
