20 Most Recent Panasonic KX-TG6700 Phone Questions & Answers
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
Panasonic... | Answered on Oct 06, 2012
unlock PANAXONIC p2102v which is giving UIM not recongnizing erro
i have a foma p2102v which gives this error UIM not recognize please send me its country code and soution of this error i shall be very thank full to you
Panasonic... | Answered on Jan 20, 2012
Do you have a spare battery you can try? Did you make sure the receiver/charger is plugged into the wall? It is possible the last time it was in the base station, it did not contact the connections properly, and did not actually charge.
Panasonic... | Answered on Jun 11, 2011
Is it dial lock?
Panasonic... | Answered on May 11, 2011
Here is a link to your manual.You do not have to sign up for anything and there is no junk after.Click download,then enter the 5 digit code and press download again.It will open a menu.If you want to save it permananetly click save.It will most likely save to your documents folder.For 1 time use click run.You may want to save this site for future reference also.It is excellent and has a wide variety of electronics.There is mention of turning off the ringer on page 23.At the end of the manual on page 59,it mentions for a problem with BOTH ringers not working to refer to pages 23,and/or 38.Page 23 does mention the ringer volume is separate for both I believe,that may be all.Try it out and if that doesn't work try as follows.I don't have a Panasonic,but most phones have the settings available by pressing the menu button,while the phone is off,no dial tone.Pick it up and press menu.Listen in the earpiece and you should hear the menu open.To cycle through the options,obviously it will start at the top so press the directional pad down.When you get to what you want,press right once.To set the ringer,one press right should turn it on,another press right should turn it off again.For other menu options such as setting the answer machine rings before it answers,press right and it should cycle throughall of it's options and repeat after no more are available.When you have all of your options set up,I believe just turning it off will be okay.When you are setting the ringer,it should prompt you to set a certain button to save what you have set.Different manufacturers have different ways,but the basic principles of programs are usually somewhat similar.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.I really encourage responses so I can follow up properly as I know where you stand and asking someone else restarts all the explaining because we cannot see other 'Expert's' responses.Good luck,Greg
Just my kind of luck too.The manual has how to set up everything EXCEPT 1 unit's ringer.The manual says colume,ring tone and everything but.If this does not get your issue solved,please let me know.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Panasonic... | Answered on Jan 25, 2011
Please kindly visit this site to get the proper recommendation on how to fix up the problem .
please visit http://www.panasonic.com/phonehelpand the probem will be sole the is free.
Good luck and thanks for using fixya.
Panasonic... | Answered on Jan 20, 2011
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
www.devicemanuals.com/.../Panasonic/Panasonic-KXTG6700-TELEPHONE-TlRJNE1nPT.html - all in manual above
Panasonic... | Answered on May 16, 2010
Just click here to view the manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG6700.PDF
It's in PDF format. You'll need adobe Reader installed on your PC to view it. It's free to download and use.
Download Adobe reader by clicking here: http://get.adobe.com/reader/
Panasonic... | Answered on Apr 08, 2010
Yes you can go to settings menu and can switch off the backlight, this will save your battery power
Panasonic... | Answered on Jun 16, 2009
please refer to this link
n do the opposite ways when referring to pg 40..
Panasonic... | Answered on May 27, 2009
n look at page 38
hope this help.... ; )
Check this out from the Panasonic website, under support, enter your model. Here is the exact page Copy this link then Paste it in your Browser. http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/Operating-Instructions/model.KX-TG6700B.O#ts
Panasonic... | Answered on May 12, 2009
Have you telephone co. test line to home, the trouble maybe with phone lines, and nothing to do with your phones.
Panasonic... | Answered on Apr 19, 2009
Panasonic KX-TG6700 Phone Logo
40 questions posted
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
unlock panaxonic p2102v giving uim not
  • Lands Phones
