20 Most Recent Xitel Inport Hotwire Questions & Answers
What kind of 'recovery' did you do ?
If you did a 'factory recovery', then you will likely have to re-install the Hotwire software before it will recognize the device.
Xitel Inport... | Answered on Aug 30, 2012
Wireless devices with Bluetooth radios must be "paired" with each other before they can communicate. This involves making them discoverable and potentially entering a PIN.
The pairing process works with "Bluetooth profiles," and each device has to be compatible. For example, you can only pair a mouse or keyboard with a device that's been designed to work with that type of accessory.
Audio Players &... | Answered 13 hours ago
That device uses an electronic oscillator and it may be that one or more components inside it are failing. Unless you have special tools and knowledge, there is nothing you can do to repair it
Audio Players &... | Answered Yesterday
Picture dvds are read with different software than that required to play movies. Make sure that you actually have dvd player software installed on your system, like WindDVD or Power DVD. See this link for a few.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Audio Players &... | Answered on May 21, 2020
No one knows as you don't give enough information. Perhaps you have an Android device?
iTunes Download iTunes Now Apple CA
Audio Players &... | Answered on May 20, 2020
It sounds to me like an audio enhancement filter is malfunctioning. The pure direct on / off is a sound filter to alter the sound performance of the receiver. There is a rare possibility that there is something wrong with one of your speakers- causing certain circuits in the receiver to malfunction. A way to check for this is to connect only one speaker and an audio source. test each channel first(without pure direct) by connecting the speaker to a channel and then disconnecting it, and connecting it to a different channel repetedly, until you have gone through all of the channels. If you really wanted to pinpoint such an anomaly, then you would need to do it with every speaker through all of the channels to make cetain that this is not the case. But then again this is not very likely. I would personally just use the mode that seems to work, because something is obviously malfunctioning, or possibly burned out. And repairing it is most likely costly! I hope that you can get something out of my answer! sorry! Good Luck!
how could we know??? what thing??
Audio Players &... | Answered on May 18, 2020
In many cases, premature shutoff of your unit can be caused by a problem with the speaker wiring between the receiver and speakers. A single strand of wire in the wrong place (causing a short circuit condition) will cause the unit to shut off at anything but very low volume levels.
https://usa.yamaha.com/support/faq/audio_visual/2438.html
Audio Players &... | Answered on May 14, 2020
might be the speed you writtend the disc which is not supported, or the mp3 format may not be supported , may only support track audio format on cd,
have a look on this link see if you can read the instructions to give you a better idea of what he is capable of.
http://vault.alpine-usa.com/products/documents/OM%20INA-W900%20English.pdf
Audio Players &... | Answered on May 13, 2020
You can put into Google search the product and serial/model number and maybe find an app to download on a smart device.
Very good turntable!
Anything else I can help you with?
My lg power model mcd605 power is bad it cant on what could be the fault?
Possibly disc stuck inside.. you may have to take unit apart to correct that
Audio Players &... | Answered on May 09, 2020
Hi there.
First - Turn On The Tape Demagnatiser (should be a switch on it)
Second - Insert into cassette player
Third - Turn On cassette player
Fourth - TURN DOWN VOLUME ON AMPLIFIER TO MINIMUM (This is essential!)
Fifth - Press Play on cassette player
Sixth - After 10 seconds press stop on the cassette player
Seventh - Remove the cassette demagnetizer from the cassette player
Eighth - Turn off the demagnetizer and put back in it's usual storage place
AGAIN, MAKE SURE THE VOLUME IS TURN TO MINIUM WHEN USING THIS AS THE NOISES CAN DAMAGE SPEAKERS.
Audio Players &... | Answered on May 08, 2020
My guess is it was not designed to play blueray! With out make and model that is the best answer I can give.
If that is the case here are a few possible replacements:
Samsung BD J5100 ZA Streaming Blu ray Player Black
Sony BDPS3500 Streaming Wi Fi Built In Blu ray Player Black
Sony BDPS1500 Streaming Blu ray Player Black
SONY CORPORATION Sony DVP SR510H Black DVD Player
Audio Players &... | Answered on May 07, 2020
Xitel Inport Hotwire Logo
2 questions posted
Top Xitel Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Xitel Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Xitel Audio Players & Recorders
Most Popular Question
hotwire not open
  • Audio Players & Recorders
