20 Most Recent
GE 27906 Cordless Phone Questions & Answers
Outgoing call does not connect when I dial the number
depends on the telephone exchange . Suggest switching to Tone signalling . MTDF -
https://en.wikipedia.org/wiki/Pulse_dialing
Old technology- Pulse or Decadic Signalling - the line is broken by a relay contact or if even older a rotary dial manual switch contact - Dial a 9 you would break the line connection 9 times and send nine pulses.
Tone sends two frequency tones that encode the number that you selected and is a much faster dialing system and more modern method.
10/16/2017 4:36:32 AM •
GE 27906...
Answered
on Oct 16, 2017
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
