20 Most Recent
GE 27909 Cordless Phone Questions & Answers
Ge cordless phone 27909 will
The registration instructions are in the fourth column of the manual at
http://www.home-electronics.net/ge/pc/IB/27909EE1_IB.pdf
8/19/2011 7:17:34 PM •
GE 27909...
Answered
on Aug 19, 2011
I am unable to get the handset to work. There is
unplug the power adaptor and phone line from the base for about 15 minutes. plug it all back in and if you have more then one handset, you will need to drop each one into the base to sync it with your phone. the charging lite should flicker for a second or so. also test the phone line you are using with a regular phone to make sure it is working as no line generally means that there is no working phone line plugged into the base.
1/12/2011 5:18:32 PM •
GE 27909...
Answered
on Jan 12, 2011
I need to find out
Most cordless phones have the battery in the receiver piece you hold to speak and listen. Usually, on the back you will find a door that is rather difficult to slide off, and the battery is under there. Remove your batter, and take it with you to purchase a new one to make sure the size, type and connector all match. Their are a lot of variations on that type of device.
1/1/2011 8:34:02 PM •
GE 27909...
Answered
on Jan 01, 2011
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
