20 Most Recent
Uniden DECT1080-2 Phone Questions & Answers
Recording a message
You need to record the OGM message not the memo. Memo is used for just that. You can leave a memo for your other half, child, etc.
The OGM is what callers here when getting your answering machine.
1/12/2009 2:34:08 AM •
Uniden...
Answered
on Jan 12, 2009
Call Waiting
I read the manual on your phone. On some model phones there actually is a timer setting for the flash key, however there is not one for yours. The Button is marked CID/Flash on the handset. The only thing I see in the manual is a Call Waiting tone that is in addition to the telephone company tones. However it is not very clear if that actually turns the ability to press the flash for call waiting. My other suggestion is, if you have any other wired phones that call waiting works on.
Here is the manual on page 26 it tells you how to turn it on!
http://www.uniden.com/pdf/DECT1080-2om.pdf
1/12/2009 2:31:19 AM •
Uniden...
Answered
on Jan 12, 2009
My home phones are acting up!!!!
I experienced this when using this model phone as an analog adjunct to an extension on a Panasonic TA624. The problem would come and go--and was driving me nuts! Turned out the culprit was BGM (Background Music) was occasionally being activated/deactivated on that extension, by pressing the [1] key inadvertedly. Since there was no outside music source--it was not playing anything to give you a clue. Once I hooked up a music source (an MP3 player) it became obvious. Good luck on finding your problem.
mmcalli
1/25/2008 12:13:40 AM •
Uniden...
Answered
on Jan 25, 2008
Uniden DECT 6.0 cordless phones
Here are some steps that should help. I don't think that you can
Conference call
You can hold a 3-way conversation (conference
call) between your handset, an external caller and
another internal handset user.
During an external call:
1 Press . The external caller is put ?on-hold?.
2 Press or to select name, number or
the handset you want to have a conference call
with and press or key.
The called handset will ring.
3 When the called handset answers, press
to start your conference call.
4 Any handset can press at any time to
leave the conference call.
It looks like you can use the multiple system sets together, but the system is not designed to do what you are asking for.
Please repost with any other comments or questions.
Please rate this solution through fix-it.
Thank you.
7/8/2007 9:24:46 PM •
Uniden...
Answered
on Jul 08, 2007
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
- Disconnect the power cord from the base of both phones.
- Take the battery out of each handset.
- Wait for a few minutes.
- Reconnect the power cord to the base of the newer version phone and insert its battery.
- Wait for the phone to register on the base, which should take a few seconds.
- Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
- The older version phone should now register on the same base.
- Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee.
(Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
