20 Most Recent Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset Questions & Answers
To increase the volume, press cursor-up while on a call. If you go too far, press cursor-down to decrease the volume.
Panasonic... | Answered on Jun 17, 2013
The KX-TGA560 isn't an answering machine. If you have a separate answering machine connected to your phone line, please consult its documentation. If you're subscribed to a voicemail system provided by your telephone company, please contact your telephone company for instructions on accessing their voicemail system.
Panasonic... | Answered on Jun 12, 2012
The KX-TGA560M isn't an answering machine. If you have a separate answering machine connected to your phone then please consult its documentation. If you still have problems, please repost your question specifying the make and model of your answering machine.
If you're subscribed to a voicemail system offered by your telephone company, please contact them for instructions on accessing their voicemail system.
Panasonic... | Answered on Mar 29, 2012
Hello,I suspect the mouth piece could be faulty,and I will strongly advice you fix that,either get a new mouth piece for replacement or you get a new handheld.those are the available options.
You can get the mouth piece from your point of purchase and also get it fixed there.
Wish you good luck.
Take care.
Panasonic... | Answered on May 25, 2011
Cannot hear from handset or earphone, can only hear from speaker phone. What can be the problem.
Panasonic... | Answered on Mar 16, 2011
press the circular button
Panasonic... | Answered on Mar 13, 2010
you need to replace it with new one and place it back ok
Panasonic... | Answered on Jul 17, 2009
the network provider will give you the divert codes. *21 (the number) #
and #21# to take it off
Panasonic... | Answered on Jun 01, 2009
They probley screwed u... It was probably broken...
Panasonic... | Answered on May 25, 2009
You need to call your Telco and request this service.
Panasonic... | Answered on May 06, 2009
the digital answer machine did not torn on? Why?
Panasonic... | Answered on Jan 12, 2009
Hi Dana, I finally bought a new phone!  I came home & plugged it in & it had the same problem.  I called my cable provider (I have digital voice through them) and they were sending someone out when I discovered that I had moved my cable box a while back & realized that I had the front (where all the lights are) aiming into a wall.  I moved the box & then my phone worked.  I was also have a lot of problems with static & garbled sounding voice on my old phone which has been solved by the new & improved cordless phone.  Good luck!!! Maggie
Panasonic... | Answered on Jun 12, 2008
The microphone in handset is broken!
Panasonic... | Answered on Nov 21, 2007
KX-TGA101S is an add-on handset for a Panasonic KX-TG1000 series cordless phone system. One of the models that is compatible with the handset is the KX-TG1032S. You can find the manual for the phone system on the product page here: https://shop.panasonic.com/support-only/KX-TG1032S.html . Assuming that you do not have voice mail from your telephone provider, you can change the number of rings from the Answering Device Settings Menu.
Start with the phone system in standby (no incoming or outgoing calls) mode. Press Menu and use the up/down keys to navigate to Answering Device. Press OK to enter the sub-menu. Navigate to Settings and press OK. Navigate to Ring Count and press OK. Use the up/down arrows to choose a new number of rings. Press OK to save and press Off to exit the menu system. Note: if the ring count is set to Toll Saver mode, the answering system will pick up on the second ring if there are new messages. It will pick up the incoming call on the fourth ring if there are no new messages.
See page 31 of the manual for the KX-TG1032 for this information. See page 23 for the way to navigate through the menu and a list of the menu tree items. The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg1031_en_om.pdf .
I hope this helps.
Panasonic Lands... | Answered on Jun 22, 2020
Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset Logo
Popular Tags
33 questions posted
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
martin hogg
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
increase hearing volume
  • Lands Phones
