20 Most Recent Panasonic KX-TG6702B Twin Cordless Phone Questions & Answers
you need to replace the phone with a new one .
Panasonic... | Answered on Feb 26, 2018
It would be worth contacting your service provider to determine if your subscriber settings for the caller ID service are active.
Talking Caller ID Handset Dial #162 then 1 on 0 is off
Base Unit caller id Dial #*162 1 on 0 is off
Guess this toggles it from 1 or 0 in the settings
http://eng.faq.panasonic.com/app/answers/detail/a_id/20750/~/troubleshooting---caller-id-is-not-working.
You might unplug the base station for a few seconds and then plug it back in. It might restore the function.
http://phone.manualsonline.com/manuals/mfg/panasonic/kx_tg6702_1.html
Panasonic... | Answered on Nov 26, 2017
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Panasonic... | Answered on Oct 06, 2009
There are dozens of models and yours is a mystery to us :>)
Google
make model manual
my guess is that yours has been programmed NOT to make outside calls.
Panasonic Lands... | Answered on Aug 02, 2020
Request the diagram directly from Panasonic.
Panasonic Lands... | Answered on Jul 25, 2020
Hi dear Lavon Bonar:
RE: Unblocking phone numbers on your Panasonic landline:
Dial *60 to access blocked numbers:
Your Selected Call Rejection Service is probably now ON;
To TURN OFF Call Rejection Service, dial 3.
OR
To REMOVE ALL blocked entries Dial 08*
That's it. Glenda Gammel 9/21/2017
Panasonic Lands... | Answered on Jul 21, 2020
KX-TGA101S is an add-on handset for a Panasonic KX-TG1000 series cordless phone system. One of the models that is compatible with the handset is the KX-TG1032S. You can find the manual for the phone system on the product page here: https://shop.panasonic.com/support-only/KX-TG1032S.html . Assuming that you do not have voice mail from your telephone provider, you can change the number of rings from the Answering Device Settings Menu.
Start with the phone system in standby (no incoming or outgoing calls) mode. Press Menu and use the up/down keys to navigate to Answering Device. Press OK to enter the sub-menu. Navigate to Settings and press OK. Navigate to Ring Count and press OK. Use the up/down arrows to choose a new number of rings. Press OK to save and press Off to exit the menu system. Note: if the ring count is set to Toll Saver mode, the answering system will pick up on the second ring if there are new messages. It will pick up the incoming call on the fourth ring if there are no new messages.
See page 31 of the manual for the KX-TG1032 for this information. See page 23 for the way to navigate through the menu and a list of the menu tree items. The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg1031_en_om.pdf .
I hope this helps.
Panasonic Lands... | Answered on Jun 22, 2020
Default code is 111
You are entering the wrong remote access code. If you have forgotten your remote access code, enter the remote access code setting to check your current code (page 39).
Page 53 of the Manual
https://panasonic.ca/PCS/OperatingInstructions/KXTG6522,%2023,%2024,%2031,%2032,%2033,%2034%20E.pdf
Panasonic Lands... | Answered on May 28, 2020
Don't worry all the Experts know that anything Panasonic KXTG is a phone with base unit. You were the one who posted it to the Panasonic Washing Machine Category.
I wouldn't say my answer was 'totally useless', you didn't understand my answer. I have elaborated on it with two further explanations. Either there is a Fax Machine trying to connect to you, or you have the volume turned up too high and you are getting 'feedback'.
Panasonic Lands... | Answered on May 11, 2020
https://www.youtube.com/watch?v=BKfEsZEaf5I
Panasonic Lands... | Answered on Apr 18, 2020
Hi! Below is the image of your phone keyboard with the PROG key circled.
If the image is smallish to see hit the CTRL + keys and the image will enlarge.
Regards and thanks for using Fix Ya.
Panasonic Lands... | Answered on Apr 13, 2020
Panasonic KX-TG6702B Twin Cordless Phone Logo
7 questions posted
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
martin hogg
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
line will busy static
  • Lands Phones
