20 Most Recent
Casablanca Fan W-62 LCD Remote Control Questions & Answers
No display appears after replacing the batteries.
1) tightt the spring contacts batteries with pliers for better contact2) open the remote and clean the keypads from dirty, oxide with contacts cleaner.3) resoldert the wires connector contact batteries.4) Otherwise you must go to the repair shop TVGod bless you
Remote does not work. fan
If the screen on the remote reacts when you press the buttons and the dip switches haven't bee changed then the defect is not in the remote, it's in the fan itself. That would explain the noise coming from it, which most likely is caused by the oscillation of the propeller. This in turn is caused either by a loosening of the securing bolts (tighten them) or by an excessive wear of the bushings on the motor. In that case the fan is effectively dead, it will be cheaper to buy a new one than to call a repairman to replace the motor.
If the switches have been altered use this manual to set them right
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/AdvanTouchCommonRep/W62-W63InstallOperation.pdf
Fan has worked fine for
Take the remote aparts,clean the PCB with some Q tips with rubbbing alchahol.Check the back of the rubbers buttons back back films.If clean the PCB with some rubbing alchahol and the back films of the buttons are good.After the process,the remote should work.Not,than the reomote CPU is dead and it useless.
Remote control have become sticky
I have the same problem; the remote has become quite disgusting to touch. I recently sent a complaint to the company via the customer service page on the Casablanca Fan web site. They are sending a replacement, no questions asked, so clearly the problem is known to them and they have no solution other than replacement.
Casablanca Isatope 52 inch fan not working
You are exactly correct...
Power flows to the fan as soon as the circuit is closed.
All the light (diming) and motor power, speed & reverse are all
controlled by tones from the switch to a
receiver inside the fan housing... (only 2 wires + ground).
I have BOTH (the old style 3 switch) and the
newer 4 button "W32" ... use the same tones BUT ARE
NOT INTERCHANGEABLE...
In my opinion
The premier site for ALL
FAN switch troubles
is the "
FAN-MAN" (see below).
Or call... 1-952-898-2754
Fan Man Lighting
Carnac the Magnificent
