20 Most Recent Thomson RP5600 Clock Radio Questions & Answers
You may be able to find a manual by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Thomson RP5600... • Answered on Oct 23, 2013
Hi, Same here but I DO have the manual. Still took a lot of working out tho. Make sure you have decent batteries installed (Should be changed every year) so that the time will remain next power out.
If you send me your Email address I'll copy the relevent page for you. To rizla01 - at - yahoo.com
Thomson RP5600... • Answered on Dec 24, 2009
I had the same problem. Looked here for help and found no solution, so dug through the attic till I found the manual. Thankfully I had kept the box. Here's the instructions from the manual:
Setting the Time
  1. Press the SET button, the ":" will flash on the display.
  2. Press REV or FWD to set the time.
  3. AM or PM icon will show beside the time.
TIP: No icon will be flashing if all selectors are set, if you see any icon flashing on display, press the SET button repeatedly to confirm everything is set correctly.
Thomson RP5600... • Answered on Dec 17, 2008
Probably something came loose inside. Most likely the wire that powers the lcd came loose. It's possible it shorted out too. Personally I'd return it and not take it apart. If you can't fix it you'll void the warranty and the store might not return it if they see it's be disassembled. You're better off exchanging it since it's already had an issue after one day. It may be an indication of the workmanship of that unit in regards to it's longevity. I hope this has explained your question in detail. If I've helped you please don't forget to rate me. Peter
Thomson RP5600... • Answered on Oct 04, 2007
Hello Jan, tell us what model is your portable CD player Thomson I wait your answer Greetings Franco Dosil Hola Jan, comenta que modelo es tu portable CD player Thomson Espero tu respuesta Saludos Franco Dosil
Thomson Audio... • Answered on Feb 20, 2020
Murdo's tip to trim off the cover of the AA battery base to expose a few mm of metal is spot on. Replacement rechargeable batteries for my Thomson wireless headphones did not charge, no green light, utterly frustrating, till I read Murdho's suggestion. Thanks for that
Thomson Audio... • Answered on Oct 02, 2018
A "Remote code" for what "device" to talk to your thomson x101b??
Thomson Audio... • Answered on Feb 10, 2018
http://www.thomsonaudiovideo.eu/ It might be a french product . Not sure if you need to speak french but you could ask them if there is a user manual ? Maybe use a translator web site and put french in as well in your request .
Thomson Audio... • Answered on Jan 25, 2018
Thomson RP5600 Clock Radio Logo
8 questions posted
Top Thomson Audio Players & Recorders Experts
Jean Sintulaire
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Audio Players & Recorders
Most Popular Question
thomson rr520u alarm clock
  • Audio Players & Recorders
